AussieIan Posted July 9, 2006 Share Posted July 9, 2006 Is there a problem with using a hose clip to seal the gear box side of the rubber boot rather than the thin S/S bands on the drive shaft. Its just easier to tighten with the shaft still on the car. I'm worried about the balance. Rgds Ian Link to comment Share on other sites More sharing options...
lmdew Posted July 9, 2006 Share Posted July 9, 2006 Balance will be a concern. I use 0.320 safety wire about 6 wraps and do them that way. Pull it good and tight and it will seal and not damage the boot. Link to comment Share on other sites More sharing options...
Subie Gal Posted July 9, 2006 Share Posted July 9, 2006 subaru does make some beefier, huge straps for the CV's but these are for the WRX/STi models what model do you have? and yes, I have heard of using hose clamps in place of these bands at times... Jamie Link to comment Share on other sites More sharing options...
Commuter Posted July 9, 2006 Share Posted July 9, 2006 AussieIan said: Is there a problem with using a hose clip to seal the gear box side of the rubber boot rather than the thin S/S bands on the drive shaft. Its just easier to tighten with the shaft still on the car. I'm worried about the balance. Rgds Ian I used regular worm gear hose clamps on my old Civic years ago after the mechanic messed up the OEM bands. Never had an issue. If you are worried about balance, you could probably disassemble one hose clamp, slip the 'worm' fastner part of it onto another hose clamp, then position it 180 degrees from the other worm fastener, thereby providing balance. I'm not sure just how doable this is. I haven't studied one close enough. Just an idea. Commuter Link to comment Share on other sites More sharing options...
a97obw Posted July 9, 2006 Share Posted July 9, 2006 Much easier and probably a better solution than using a hose clamp is to use one of those big heavy duty cable ties (like the coppers use to haul you off:eek: )--just loop it around the boot, through the slot and pull it up tight. Cut off the excess. These are what the 912 Porsche guys (including myself) are doing these days with regard to securing the CV joint boots to the axle shaft. Link to comment Share on other sites More sharing options...
AussieIan Posted July 9, 2006 Author Share Posted July 9, 2006 Thanks Guys, the cable tie solution seems to be the go. Link to comment Share on other sites More sharing options...
glmf Posted July 10, 2006 Share Posted July 10, 2006 ditto on the wire ties or zip ties as some people call them, I started doing this on my atvs to allow for greasing and it works very well. Just a quality tie wrap, like one with a metal locking tab,,, Link to comment Share on other sites More sharing options...
