WheaT_BeeR_MaN Posted July 9, 2006 Share Posted July 9, 2006 ok i have a 83 gl10 wagon all the windows used to roll down now recently the right rear has stopped i took it apart hooked juice to it to make sure it worked and it does. now im wonder how or where the wiring could be messed up or if there something else? thanks:confused: Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 9, 2006 Share Posted July 9, 2006 All the relays should be located under your drivers seat. Remove the seat and that should help you start your search. -Brian Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2006 Share Posted July 9, 2006 Usually it's just the switch contacts. They can be dissasembled and cleaned. GD Quote Link to comment Share on other sites More sharing options...
St Nickolas Posted July 10, 2006 Share Posted July 10, 2006 Usually it's just the switch contacts. They can be dissasembled and cleaned. GD I'm with GD. Take the switch out, go to a well-lit place with some room, and relaxed state of mind. Not a tough job, but a bit tedious with a need for attention to detail and steady hands. Lay down an old t-shirt on a flat surface and begin to dissasemble the switch. There are several small parts including springs. The contacts carry lots of current and will often carbon up the surface. Smooth and clean them with a contact points file, or emery cloth. Reassemble. Reinstall Nick Quote Link to comment Share on other sites More sharing options...
daeron Posted July 10, 2006 Share Posted July 10, 2006 electrical problems like that can be made much easier to troubleshoot and fix if you have a multimeter.. and harbor freight has digital multimeters for five bucks. alot of auto parts stores and home depot stores have them el cheapo as well. they are certainly not the best units, but they are a bit more information than a test light at least, and it makes a WORLD of difference. my 5 dollar disposable harbor freight multimeter is one of the best five bucks i ever spent. I have access to a better one when i NEED it, and actually got my old craftsman working again.. but its a worthy investment. Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 10, 2006 Author Share Posted July 10, 2006 great thanks guys i will take the seat out in a little bit and check it out. im betting if its under there, that all the water that has been in my car its effected it. ive taken it threw many ponds no lakes or creeks yet Quote Link to comment Share on other sites More sharing options...
soobscript Posted July 11, 2006 Share Posted July 11, 2006 I took my wagon's master switch apart... every contact has a thick black carbon layer. I'd imagine cleaning will help a bit. Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 11, 2006 Share Posted July 11, 2006 It may be easier to use a test light to see if the switch is ok. Just probe the switch contacts to see if they are making contact when you move the switch. You can also swap the switch with the one from the other side. The problem may also be a broken wire in the door jamb. Quote Link to comment Share on other sites More sharing options...
SkankinPickle Posted July 12, 2006 Share Posted July 12, 2006 the wires that go from the power window relay to the center consol switch run under the carpet right under your feet beneath the carpet in the front. maybe the insulation has worn off in a spot and grounded out some how. I say first off lift up the carpet on the driver's side and check the condition of the wires. Quote Link to comment Share on other sites More sharing options...
