Axles are broken
Dang, just got done replacing drive side wheel bearings, and went for a test run and broke the pass side axle. Is it ok to drive with the broke axle still in the car? If not, what do I need to do to drive the car until I can get an axle? Oh yeah, the car is a 4wd Loyale
Depends on how it broke - I've had them rip free of the joint (inners and outers) and start flopping around down there. Nasty things can happen including destruction of the brake lines. If you must drive it, take the axle out, remove the outer spindle, and reinstall it without the axle shaft or inner joint. THEN drive it in 4WD.
