Uberoo Posted July 13, 2006 Share Posted July 13, 2006 ok the headgasket(supposedily failed) on my brat.so I replace both headgaskets along with having the heads resurfaced.same symtoms...so I pulled the left side head because a lot of milkshake was coming from there.it didn't seat.so I replaced it.I adjusted the valves.I made sure everything was torqued to the right specs.it still shoot milkshake out of vent covers...Im just gonna save up and pull a ej22 at pull and save... what pisses me off is if I didnt spend the money on resurface and parts I could have spent and extra 10 and gotten a motor from pull and save... grr Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 13, 2006 Share Posted July 13, 2006 Small amount of milkshake out the valve covers can indicate bad intake manifold gaskets. It is VERY common for them to leak. Have you flushed the oil, and filled it a couple times to get all the water out? And have you cleaned out the entire PCV system? The EA81's are extremely rugged - I've done quite a few HG's on them and had nothing but good results. GD Link to comment Share on other sites More sharing options...
Turbone Posted July 13, 2006 Share Posted July 13, 2006 Did you check for cracks between the valves? Sometimes, if overheated enough, it will crack up into the exhaust port where the water jacket is. No matter how many times you put HG's and resurface the heads, it will never seal. Link to comment Share on other sites More sharing options...
Uberoo Posted July 13, 2006 Author Share Posted July 13, 2006 the machine shop would have said something if heads were cracked.as for the milkshake.I have brand new intake gaskets,brand new HG,brand,brand new valve cover gaskets.so Im just gonna save up for a new motor unless someone has a known good set of EA81 heads I could have for $0. hell at present Im considering just selling the brat and buying a damn nice wagon.then I could take friends 4x4ing... BTW how much is a 1984 brat worth with some rust around rear fenderwells,some rust on lower doorsill,and some various dents/dings.interior is ok,drivers seat is torn.and motor doesnt run.thinking of listing it for 700 or best offer. Link to comment Share on other sites More sharing options...
subyrally Posted July 13, 2006 Share Posted July 13, 2006 BTW how much is a 1984 brat worth with some rust around rear fenderwells,some rust on lower doorsill,and some various dents/dings.interior is ok,drivers seat is torn.and motor doesnt run.thinking of listing it for 700 or best offer. hmm, indeed, let me know if you go that route. on second thought, thats a bit of a hike, just realized that you are nearly on the west coast. Link to comment Share on other sites More sharing options...
75subie Posted July 13, 2006 Share Posted July 13, 2006 your brat should be worth $700, look at this one, it sounds comparable eccept it runs. (no its not a turbo, i asked) http://minneapolis.craigslist.org/car/180187761.html Link to comment Share on other sites More sharing options...
Uberoo Posted July 13, 2006 Author Share Posted July 13, 2006 how much is a comparable EA82 wagon that runs worth?I would chose ea81 for the reliablity,but I dont really like the tail end of EA81 wagons...or I suppose I could go with a hatch. Link to comment Share on other sites More sharing options...
75subie Posted July 13, 2006 Share Posted July 13, 2006 a comparable ea82 wagon that runs usually ranges from $500-800, actually, you can find them all day on WA and OR craigslists, and the majority of them are rust free! hatches are hard to find though, IdahoJak, a member on here has a real nice one for $950 tho, its from WA, you may want to contact him...... Link to comment Share on other sites More sharing options...
Uberoo Posted July 13, 2006 Author Share Posted July 13, 2006 just put an add in the local money saver.Im selling it for $800 or best offer.sad.Now I just have to wash it(first time ever) and remove all non factory parts,weber included. Link to comment Share on other sites More sharing options...
SuperBrat Posted July 13, 2006 Share Posted July 13, 2006 Damn dude, im 50 miles from you, have a 84 hatch 4x4 hatch all original ,... Link to comment Share on other sites More sharing options...
Uberoo Posted July 13, 2006 Author Share Posted July 13, 2006 trade? Link to comment Share on other sites More sharing options...
