Splinter Posted July 13, 2006 Share Posted July 13, 2006 Hey guys, Im from the Legacycentral BBS My Legacy Turbo just blew up ANOTHER transmission, so Im taking it off the road until I can afford to buy a built up WRX tranny. In the meantime, Im checking out an 86 XT Turbo tonight. $500 Its got a bad CV joint (not a huge deal I know) and Im going to do a compression test and check the rad cap for bubbles while the engine is on. Aside from that, anything else you'd suggest? Im going to most likely throw on my VF11 and downpipe from my legacy, as well as a few other bits and pieces. Ive got an upgraded alternator which I hope will fit. This is gonna be my first EA82T car. Im gonna start looking for another set of heads and a pair of headgaskets right away, since I want to up the boost a little (intercooled) Quote Link to comment Share on other sites More sharing options...
benebob Posted July 13, 2006 Share Posted July 13, 2006 www.xt6.net will give ya all the help you need. Congrats on the purchase. Quote Link to comment Share on other sites More sharing options...
mrroot Posted July 13, 2006 Share Posted July 13, 2006 In the meantime, Im checking out an 86 XT Turbo tonight. $500 Its got a bad CV joint (not a huge deal I know) and Im going to do a compression test and check the rad cap for bubbles while the engine is on. Aside from that, anything else you'd suggest? Kick rump roast, man. I've got the same car. Sounds like you have an idea of what you're doing so I won't subject you to the standard deluge of "things to check". There really isn't too much beyond I'd recommend. Although... Pop off the aluminum intake doohickey ( says "Subaru Turbo" and connects the turbo unit to the throttle body - you can't miss it - it's right in the middle of the engine and it's pretty when you clean it up ) and look inside. Check the aluminum tube and the throttle body for signs of oil. If you see any, expect to replace the turbo soon. Also, look for any leaks around the turbo itself where the coolant and oil lines connect. You should be familiar with TOD, so don't worry if you hear that - it's easily repaired. Can't think of anything else at the moment. I got mine for $350, so you should offer $250 and go from there. Good luck! Quote Link to comment Share on other sites More sharing options...
Splinter Posted July 13, 2006 Author Share Posted July 13, 2006 You should be familiar with TOD, so don't worry if you hear that - it's easily repaired. TOD? Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted July 13, 2006 Share Posted July 13, 2006 Tick Of Death (t.o.d.) Quote Link to comment Share on other sites More sharing options...
Splinter Posted July 13, 2006 Author Share Posted July 13, 2006 Dont think we have that on the TLegs... what is it? Quote Link to comment Share on other sites More sharing options...
jeffast Posted July 13, 2006 Share Posted July 13, 2006 the hydrolic lash adjusters for the valves make a loud ticking noise almost all old soobs get it at one point or anouther it's easy to fix and even if you don't it's not serouse Quote Link to comment Share on other sites More sharing options...
Splinter Posted July 13, 2006 Author Share Posted July 13, 2006 ah thanks Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted July 14, 2006 Share Posted July 14, 2006 Pop off the aluminum intake doohickey ( says "Subaru Turbo" and connects the turbo unit to the throttle body - you can't miss it - it's right in the middle of the engine and it's pretty when you clean it up ) and look inside. Check the aluminum tube and the throttle body for signs of oil. If you see any, expect to replace the turbo soon. Um, not so. With a 20 year old motor, you'll likely have some PCV issues, and so you will get oil condensation on the intake plenum (the intake doohickey as you called it). In fact, that's what most of the oil found in the intake is from. When Turbo seals start to go, they go really quick, so you'd know... But, he's probably gonna put his VF11 in it anyways so no problem BTW, I own an 86 XT Turbo. I love it. Seems most of the XT Turbos are 86 models. Crazy. Quote Link to comment Share on other sites More sharing options...
mrroot Posted July 14, 2006 Share Posted July 14, 2006 Um, not so. With a 20 year old motor, you'll likely have some PCV issues, and so you will get oil condensation on the intake plenum (the intake doohickey as you called it). In fact, that's what most of the oil found in the intake is from. When Turbo seals start to go, they go really quick, so you'd know... Hrmm... So the PCV connection on the intake *to* the turbo could get some oil in it, and therefore it would go *through* the turbo and appear in the intake plenum *from* the turbo and on to the throttle body? Hrmm... I never considered this.. I guess something like a blown head gasket could get the oil foamy enough to work it's way up some of those PCV connections? Maybe I'll go back to the JY and yank that turbo after all.... Cheers Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted July 14, 2006 Share Posted July 14, 2006 I guess something like a blown head gasket could get the oil foamy enough to work it's way up some of those PCV connections? Doesn't even need to be a blown HG. I think you'll find nearly all Turbos have oil in the intake plenum. A good thing to check, since the PCV hoses meet up right after the air cleaner, check the air cleaner and the air tube out for oil. If there is no oil there, then be concerned about the turbo. Quote Link to comment Share on other sites More sharing options...
Splinter Posted July 14, 2006 Author Share Posted July 14, 2006 No-go. Blown headgasket and the 4WD doesnt work. My search continues Quote Link to comment Share on other sites More sharing options...
Manarius Posted July 14, 2006 Share Posted July 14, 2006 I just blew up ANOTHER transmission on my Turbo Legacy, so Im taking it off the road until I can afford to buy a built up WRX tranny. In the meantime, Im checking out an 86 XT Turbo tonight. $500I fixed your post for you. Quote Link to comment Share on other sites More sharing options...
Splinter Posted July 14, 2006 Author Share Posted July 14, 2006 Quote Link to comment Share on other sites More sharing options...
