Uberoo Posted July 13, 2006 Share Posted July 13, 2006 what cars have the dual range transmission?4 or 5 speed?Im looking at a 1994 4x4 loyale with a 5 speed.is that a 5 speed DR? Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted July 13, 2006 Share Posted July 13, 2006 There is 4sp d/r and 5sp d/r.You will want a 5sp d/r out of a 85-89 GL wagon.Will bolt right up to your engine, but you will need to cut the floor where the trans will come through a little,but nothing major. The one you are looking at is definately a push button 4x4. Link to comment Share on other sites More sharing options...
ballitch Posted July 14, 2006 Share Posted July 14, 2006 if it has 5 forward gears, and has 2 gear shift levers, its a dual range tranny. if you get a D/R tranny from a turbo car, the low range is like 1.20:1 whereas the N/A dual range is 1.59:1 or something along those lines. ~Josh~ Link to comment Share on other sites More sharing options...
mikeshoup Posted July 14, 2006 Share Posted July 14, 2006 90+ do not have Dual Ranges in them. If you want to put a dual range in, any from 85-89 non-turbo would drop right in. Link to comment Share on other sites More sharing options...
Subafly Posted July 14, 2006 Share Posted July 14, 2006 I didnt even need to cut a hole in my 91 loyale it was already there, just covered up by a plate. Maybe just buy an 85-89 gl wagon and save yourself the trouble. They are cheaper too. Fuel injection is nice though. Link to comment Share on other sites More sharing options...
RONAN Posted July 15, 2006 Share Posted July 15, 2006 I had one installed in my 93 Loyale wagon. You have to cut out a hole for the transfer lever but it`s really easy. Also, try to get the mounting plates that hold down the console from the donor car. It makes things easier. Link to comment Share on other sites More sharing options...
