the sucker king Posted November 2, 2003 Share Posted November 2, 2003 i found an lsd at the junkyard in an rx. the rear wheel was hard to turn and the other rear wheel spun in the opposite direction like an open diff. it had the lsd label, is that something that could be fixed or is it shot? Link to comment Share on other sites More sharing options...
Snowman Posted November 2, 2003 Share Posted November 2, 2003 Maybe the clutch mechanism inside has just totally disintegrated. It's also possible that the lsd failed and was replaced with an open diff, but they left the sticker on. Link to comment Share on other sites More sharing options...
ezapar Posted November 2, 2003 Share Posted November 2, 2003 LSD or VLSD?? I had a VLSD that would do that sometimes. Other times it would make the other wheel turn the same direction. Link to comment Share on other sites More sharing options...
mcbrat Posted November 2, 2003 Share Posted November 2, 2003 is it out of the vehicle now? stubs should turn by hand either direction. the clutch packs in the LSDs can be rebuilt, and shimmed to different break-away points... I think stock is like 45 ft/lbs or 85.... Link to comment Share on other sites More sharing options...
Dr. RX Posted November 2, 2003 Share Posted November 2, 2003 Did you pull the rear cover to see if someone might have just switch the rear cover onto an open diff. That would be a crewl joke, but it could happen. If it is a real LSD, then it is worth pulling and getting the clutch pack rebuilt or replaced. Link to comment Share on other sites More sharing options...
cole098 Posted November 4, 2003 Share Posted November 4, 2003 I hate to ask a stupid question but again I need a edge-a-ma-cation again.. LOL When you pull one out doyou just open the cover and reove the gears inside or do you remove the whole pumpkin ball... Link to comment Share on other sites More sharing options...
the sucker king Posted November 5, 2003 Author Share Posted November 5, 2003 ezap- it was a 3.7 lsd snowman and dr rx- i don't think it had been swapped out, cause it was an rx and had the fulltime 4wd tranny, so wouldn't they have had to swap the tranny out too? unless that's why it was in the junkyard. mick and rx and any one else- i've never opened up a diff to see what all is involved. how hard is it to rebuild? what should i look for before i spend money to make sure it can be salvaged? i would like to get it this weekend if it is still there and the price is reasonable. help me please!!! and cole98- you can pull the whole pumpkin and the goodies are in it and can be swapped etc. so either way, depends what you are doin. Link to comment Share on other sites More sharing options...
mcbrat Posted November 5, 2003 Share Posted November 5, 2003 Cole98: if you're getting it from a yard, get the whole pumpkin. you have to remove the stub axles, then the side bearing cups before you can pull the LSD carrier... John: pull both axles off the diff stubs, then see if you can turn the stubs by hand... there are about 8 bolts on the back cover of the diff that you can take off to look inside. watch the oil though. LSD gear oil tends to be on the stinky side on the ones I've pulled apart. I've got pics somewhere of the innards. I'll try to find them tonight if no one else has got any.... a LSD carrier will have a solid cylinder (plates inside) that is attached to the ring gear. In the open diff, you can see all the spider gears, etc... how many miles on the RX. there have been lots of auction where the ad is aimed at Datsun guys, and they claim that since soobs are primarily FWD that the LSD should be in better shape. This is not true. The clutch plates inside are still doing their job whenther you're in 2wd, 4wd or FT4WD w or w/o diff lock. the plates are "locked" until enough of a speed difference (tight corner) where they break loose to act like an open diff. Link to comment Share on other sites More sharing options...
XSNRG Posted November 5, 2003 Share Posted November 5, 2003 Tranny would not need to be swapped, there are 3.7 open diffs too. Pop the back cover off and see if it has clutch plates or gears, then you will know. Link to comment Share on other sites More sharing options...
the sucker king Posted November 7, 2003 Author Share Posted November 7, 2003 thanks for the input mick i'm on it! sounds like all i have to do is verify that it's an lsd and it's worth getting. xsnrg- what i meant was that running an open diff behind the full time tranny would not be wise, right? wouldn't it kill the diff or the tranny? Link to comment Share on other sites More sharing options...
Dr. RX Posted November 7, 2003 Share Posted November 7, 2003 No, running with an open diff wouldn't hurt the center diff. The center diff is kind of an open diff until it is locked, and it only controls the power going to the rear diff. In fact all of the front diffs are open diffs and that doesn't screw up the tranny. Link to comment Share on other sites More sharing options...
