Newly rebuilt EA82, runs great but WHY low MPG!?!?!?
I just rebuilt the engine and i've put about 1200 miles on it. It runs great but its getting crappy mileage, and i dont know why. Can anyone one help??? Any ideas???? The only thing that i have changed on the car since putting the engine back in is the tires. I got new tires that are a little bit wider than the old ones. Could this effect my millage??? Thanks for any help!!!!
The 5 things I would check are: brake drag - jack up each wheel and put in neutral with the e-brake off and check for ease of rotation; possible vacuum leak - pull off a vacuum hose while it's running; if it doesn't run worse, then you have a vacuum leak; rich carb? - are your plugs black?; wrong sparkplugs - just use ngk; bad oxygen sensor.
Now that you've plugged that O2 sensor back in, reset the ECU. Disconnect the negative on the battery, and hit the brakes (the brake lights will drain any power left in the system). Then wait like 10 minutes, and reconnect the battery.
This will force the ECU to set a baseline again without waiting for it to try and learn.
