cmjmarvin Posted July 15, 2006 Share Posted July 15, 2006 These are not as straightforward as you would hope. One would assume that if you remove the two screws on the lower part of the knob, the knob would come right off. Hah. What is then necessary is to remove the push button from the knob. To do this, take a longnose plier and pull the spring clip down and out of the bottom of the push button. WARNING. What will then happen is that the button and its various parts will be shot out of the knob by a spring, and may end up in inaccessible places on the floor. Naturally, NONE of these parts can be purchased without buying the entire knob assembly. SO REMEMBER, when you pull the spring clip, keep your finger on the knob and let loose of it gradually, so it stays in the knob. At this point you can pull the knob up and off the column. And don't lose the spring clip; it's small and easy to lose, and, once again, cannot be purchased, etc. etc I hope I have saved someone a headache with this post. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted July 15, 2006 Share Posted July 15, 2006 There is no such place as "inaccessible" in a car if you start taking out stuff... seats are usually only 4 bolts to remove Quote Link to comment Share on other sites More sharing options...
jon38iowa Posted July 15, 2006 Share Posted July 15, 2006 I just replaced mine; I will add, it is a good idea to put down a sheet as the tiny spring may fly out like mine did, moreover, it is tricky to get the new one installed as the tiny spring is supposed to go in to a rather a small hole in the shift mechanisism.It took me a couple of tries,and unless you get it together perfectly, the shift knob will not work. Good luck. John Quote Link to comment Share on other sites More sharing options...
