MSSLGECKO Posted July 20, 2006 Share Posted July 20, 2006 I need to replace my power steering pully. My question is, is this the same as all non-turbo EA81 pulleys? Is it possible to use an EA82 pulley? Thanks Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2006 Share Posted July 20, 2006 EA82 pully will work (same pump). Just make sure it's from a two-v-belt setup and not the MPFI XT engine with the serpentine. And make sure you get one with the same mounting style - some have a single acorn nut, and some have 4 nuts or bolts or something. Or grab the whole pump. EA81 non turbo uses a completely different pump. GD Link to comment Share on other sites More sharing options...
MSSLGECKO Posted July 20, 2006 Author Share Posted July 20, 2006 Thanks, that helps a bunch! I suppose I'll just take my pulley off and compare to a new one before buying. Is there a good place to buy new units, or should I just bank on J/Y ones? Link to comment Share on other sites More sharing options...
mikeshoup Posted July 20, 2006 Share Posted July 20, 2006 Junkyard FTW Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 20, 2006 Share Posted July 20, 2006 I got one from an EA82 turbosedan..... Link to comment Share on other sites More sharing options...
