Ever Victorious Posted July 20, 2006 Share Posted July 20, 2006 The A/C on my 6 is shot... not sure I want to bother fixing it since it appears to be held together with duct tape. That, and it's not my daily driver, so that's a lot of money for not a lot of bang. I'd like to remove as much of the A/C system as possible, and certainly the easiest thing to get rid of is the compressor. Without this, obviously, I will need a shorter belt. Has anyone done this? If so, which belt is the correct replacement? Link to comment Share on other sites More sharing options...
mikeshoup Posted July 20, 2006 Share Posted July 20, 2006 Jeffast is currently running with out A/C on his 6. He'd know more about what to do. You can remove the A/C condensor, hoses, compressor, probably other things to. Just before you do, have a shop recover any R12 left in it. If you vent it to the atmosphere you will make me angry. Link to comment Share on other sites More sharing options...
jeffast Posted July 20, 2006 Share Posted July 20, 2006 you can remove the compressor, condensor, and the hoses you will save about 40 or so lbs by doing so. the condenser is mounted to the radiator it is easy to remove the two bolts in plain site hold it on. unfortunatly it has to come out the back so you have to pull the radiator give me a second i'll post the good year number for the belt i'm using EDIT: to dark outside i'll post the number tommorow because i'm lazy Link to comment Share on other sites More sharing options...
Ever Victorious Posted July 20, 2006 Author Share Posted July 20, 2006 Jeffast is currently running with out A/C on his 6. He'd know more about what to do. You can remove the A/C condensor, hoses, compressor, probably other things to. Just before you do, have a shop recover any R12 left in it. If you vent it to the atmosphere you will make me angry. One of the fiddly bits that looks like it's for charging/discharging the system is currently held together by duct tape (the way I got it). I'll have Smart Service check when the car's down there, but I'm 99% certain the previous owner already vented it. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2006 Share Posted July 20, 2006 Just depress the check ball on the pressure side of the compressor a tiny bit - you'll know real quick if anything is in there. Me - I just vent that crap (yeah - I'm no bunny hugger - sue me), and fill with R134. Make sure you replace ALL the o-rings tho. GD Link to comment Share on other sites More sharing options...
jeffast Posted July 20, 2006 Share Posted July 20, 2006 it sounds like his system is a little past a simple repair he said he didn't want to put allot of money into it Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2006 Share Posted July 20, 2006 Sure - but a few junk yard bits, and some 'freeze, and it should work again. There really isn't a lot to the systems, and it's mostly the compressor or the o-rings that die GD Link to comment Share on other sites More sharing options...
mikeshoup Posted July 20, 2006 Share Posted July 20, 2006 Just depress the check ball on the pressure side of the compressor a tiny bit - you'll know real quick if anything is in there. Me - I just vent that crap (yeah - I'm no bunny hugger - sue me), and fill with R134. Make sure you replace ALL the o-rings tho. GD Vent if you must, just don't expose yourself to the R12. Can cause heart problems, nervous system issues, etc. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2006 Share Posted July 20, 2006 Vent if you must, just don't expose yourself to the R12. Can cause heart problems, nervous system issues, etc. Yeah - and it can kill you if you light it on fire. GD Link to comment Share on other sites More sharing options...
jeffast Posted July 20, 2006 Share Posted July 20, 2006 Vent if you must, just don't expose yourself to the R12. Can cause heart problems, nervous system issues, etc. i was exposed to r12 and i'm still fine Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2006 Share Posted July 20, 2006 It's only harmful if you breath the burnt vapor - at least that's how I understand it. GD Link to comment Share on other sites More sharing options...
mikeshoup Posted July 20, 2006 Share Posted July 20, 2006 It's only harmful if you breath the burnt vapor - at least that's how I understand it. Since R12 is not flammable, this is moot. The vapor can cause harmful effects. Most of them short term. Sure, 9 times out of 10 you won't experience any problems, but do you wanna take that chance? Plus, most shops capable of reclaiming R-12 will do it for free... If you're lucky, they'll pay you to take it (because its so valuable in the US). So, do the environment something good, and have a shop reclaim it. That is, unless of course, you care about future generations being able to enjoy this planet. Of course, I'm just and you all will continue doing whatever it is you do when you discharge an A/C system. Link to comment Share on other sites More sharing options...
jacobs Posted July 20, 2006 Share Posted July 20, 2006 Since R12 is not flammable, this is moot. So, do the environment something good, and have a shop reclaim it. That is, unless of course, you care about future generations being able to enjoy this planet. quote] It's NOT about the enviroment but about MONEY! Follow the money trail. It's about Dupont and their profits. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 21, 2006 Share Posted July 21, 2006 Everything is flammable if you get it hot enough. GD Link to comment Share on other sites More sharing options...
mikeshoup Posted July 21, 2006 Share Posted July 21, 2006 Everything is flammable if you get it hot enough. GD Not true. It is only flammable if heat causes it to react with O2. R12 will react with O3, but not O2. I'd like to see you catch an ice cube on fire. Anyways, we should quit hijacking the thread... Link to comment Share on other sites More sharing options...
Ever Victorious Posted July 22, 2006 Author Share Posted July 22, 2006 Yeah, uhm... so got that belt part number, jeff? Link to comment Share on other sites More sharing options...
