Hi,
I replaced my thermostat, with the subaru OEM, put in new anitfreeze, and the car ran well for about an hour. Then it started to get hot as I was idling at a train stop. Turned around turned the heat on and drove and it cooled down.
Then engine light is still on and it seems to run hot. I have plenty of heat when I turn it on, but that seems to make it run cooler.
Help!!!!!
This is my wifes car and she needs it to get around.
Mike, KD7GHZ
If it runs cool while moving and overheats while idling it sounds like the fan is not coming on. Check the fan and the fan switch. Getting the air out of the system should help also but might not be the cause of the overheating when idling.
put the old sensor back in. Your car is old enough to have a corroded or clogged radiator. is it worse with the AC on. Since the heat brings down the temp you can rule out a blown HG. Check for air in the cooling system.
nipper
  • 2 weeks later...
Well, I got my Legacy fixed. I had to take to a local Subaru Repair Place, it was recommended by the Snap-On Driver that comes into my store.
It would appear that when I tried to repair the car I sort of messed it up. They fixed it and O2 Sensor and it works great.
Only cost 290 to have it done. No complaints. It's my wifes car and to have it work right is worth it.
Mike, KD7GHZ
