porcupine73 Posted July 22, 2006 Share Posted July 22, 2006 I bought a used '96 Legacy two years ago at 80k miles and now it has 100k miles. After I got it I noticed that if you cut the wheel sharply from a stop, that at idle it would just kind of stop, you had to give it a little gas to get it going. I did an Auto-RX flush, no difference, switched to Mobil1 syn ATF no difference, switched to Amsoil syn ATF, no difference. The last couple weeks, I've been driving her through the hills and dirt roads in Colden, NY and Little Valley, NY, and on some climbs the ATF would reach maybe 210 deg. F. But now, it moves at idle with the steering wheel cut all the way. I thought that was kind of cool. Any comments? This '96 Legacy seems to work awesome in the snow, whereas the '00 Outback I bought used last year doesn't seem to like to give a whole lot of juice to the rears. --Louis :; Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2006 Share Posted July 23, 2006 after a flush (NEVER use a chemical flush ion the transmission ever) it takjes a little while for TB to go away, if you dont cut u turns right after the flush. YOu did the usual fix, if it is gone thats a good thing. nipper Link to comment Share on other sites More sharing options...
ericem Posted July 23, 2006 Share Posted July 23, 2006 If its not gone its a bad thing, because its either two things, solenoid, or clutchpacks. When u turn on your car u see a light flash, more than 4 times. Like a tranny light or power? Link to comment Share on other sites More sharing options...
