Petersubaru Posted July 24, 2006 Share Posted July 24, 2006 would anyone know if I can use the fuel pump from my SPFI and bolt it up to the turbo(EA82)..would there be enough pressure provided since the SPFI is smaller in diameter then the MPFI pump Link to comment Share on other sites More sharing options...
Manarius Posted July 24, 2006 Share Posted July 24, 2006 It would probably work..but why would you want to use a lowgrade pump for a high grade engine? Link to comment Share on other sites More sharing options...
Petersubaru Posted July 24, 2006 Author Share Posted July 24, 2006 just trying to save some money since I have a spare from a SPFI..my wife never drives the turbo car more then 3200rpm and since the rpm never goes very high and the fuel delivery is never at it's max...then I was hopeing the smaller pump would work... It would probably work..but why would you want to use a lowgrade pump for a high grade engine? Link to comment Share on other sites More sharing options...
kingbobdole Posted July 24, 2006 Share Posted July 24, 2006 yes is the answer.. I have the other side, mpfi turbo pump on my spfi car... both use the same pressure Link to comment Share on other sites More sharing options...
GLCraig Posted July 24, 2006 Share Posted July 24, 2006 The MPFI Fuel Pump is rated 61-71PSI at 1.67 Pints/sec The SPFI Fuel Pump is rated 36-50PSI at 1.40 Pints/sec Link to comment Share on other sites More sharing options...
ShawnW Posted July 25, 2006 Share Posted July 25, 2006 Yours works cuz the FPR cuts it down. It wont be happy forever but in a pinch do it. Just remember...running lean is BAD news especially for a turbo. Link to comment Share on other sites More sharing options...
