WheaT_BeeR_MaN Posted July 26, 2006 Share Posted July 26, 2006 well it goes like this. i pulled the plug on the disty to figure out wtf was going on and figured out if i pull any on the right it doesnt effect anything and on the left it dies cause theyre actully working. so anyways i think it maybe a plug. any suggestions? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 26, 2006 Share Posted July 26, 2006 Rev the engine and try your method again - if it still does it throughout the RPM range, then your problem is something like a head gasket..... My guess would be a vacuum leak on that side of the manifold if it only does it at or close to idle. Check the plugs too, but that's not usually a problem for these engines. GD Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 26, 2006 Share Posted July 26, 2006 Check the plugs and if you have a compression tester check the compression on the right side. If both cylinders are bad then you may have a broken timing belt. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 26, 2006 Share Posted July 26, 2006 sounds like a broken timing belt (if this has two belts). i doubt its a blown head gasket as the typical subaru failure mode is not cylinder to cylinder but cylinder to water jacket (not that it doesnt happen). If it has one belt (i dont remeber) do a compression test, but its odd to have two dead cylinders. How many miles on this and when was the last timing belt change nipper Quote Link to comment Share on other sites More sharing options...
thealleyboy Posted July 26, 2006 Share Posted July 26, 2006 Good commentary above... I've seen also seen these kinds of symptoms with a siezed tesioner/pully system. Need to get those covers off to diagnose this possibility, however. You should try to rule out the other causes first. good luck, John Quote Link to comment Share on other sites More sharing options...
87RX Posted July 26, 2006 Share Posted July 26, 2006 I got the same problem only mine is on the left. Just put in a used engine and lined up both timing belts correctly, but only right side works. Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 27, 2006 Share Posted July 27, 2006 I got the same problem only mine is on the left. Just put in a used engine and lined up both timing belts correctly, but only right side works. Did you rotate the crank before putting the second belt on? If not, then that side may be incorrectly timed. Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 27, 2006 Author Share Posted July 27, 2006 ok so today i went and did a cylinder test and 3 out 4 should psi. so well im pretty sure its a stuck valve its #1 piston but what i did do is replace the spark plugs cause they were looking pretty bad. now my engine is running much much better not wanting to die... so im kinda lost Quote Link to comment Share on other sites More sharing options...
87RX Posted July 27, 2006 Share Posted July 27, 2006 Did you rotate the crank before putting the second belt on? If not, then that side may be incorrectly timed. Yep. Rotated the crank 360 deg and lined up with the marks on the flywheel Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 27, 2006 Share Posted July 27, 2006 Yep. Rotated the crank 360 deg and lined up with the marks on the flywheel Good deal on rotating the crank. Have you checked the compression of the cylinders yet to see what that shows? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 27, 2006 Share Posted July 27, 2006 I got the same problem only mine is on the left. Just put in a used engine and lined up both timing belts correctly, but only right side works. Dude - start your own thread - this thread concerns EA81 problems, you clearly have an EA82. GD Quote Link to comment Share on other sites More sharing options...
87RX Posted July 27, 2006 Share Posted July 27, 2006 Good deal on rotating the crank. Have you checked the compression of the cylinders yet to see what that shows? No, and I have no idea how to do that. I guess I need some help. Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 27, 2006 Share Posted July 27, 2006 Here is a link to help you out on how to do that. There are a number of sites you can get info like this from. http://www.automedia.com/Compression/CheckUp/res20010301ct/1 As GD stated, it would be best to start your own thread on this if you want to pursue this further. Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 28, 2006 Author Share Posted July 28, 2006 thanks for not talking about my problem or a solution Quote Link to comment Share on other sites More sharing options...
nipper Posted July 28, 2006 Share Posted July 28, 2006 thanks for not talking about my problem or a solution ok so today i went and did a cylinder test and 3 out 4 should psi. so well im pretty sure its a stuck valve its #1 piston but what i did do is replace the spark plugs cause they were looking pretty bad. now my engine is running much much better not wanting to die... so im kinda lost what are you talking about, three out fo four should psi? what DOES that mean. That makes no sense. What numbers did you get? Man,we try to help you but you dont tell us what you got, not to mention that scentence just does NOT make sense. We dont speak gibberish, and cant help with no information. We need to know the numbers Did you also do a wet test? What were those numbers? nipper Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 29, 2006 Author Share Posted July 29, 2006 derr i guess i should have proof read it. sorry anyways i had 3 out 4 pistons have pressure. the 3 at about 100 and the 1 at 0 which is piston 1. i can also pull off the disty cables on the right side and doesnt effect the engine Quote Link to comment Share on other sites More sharing options...
nipper Posted July 29, 2006 Share Posted July 29, 2006 derr i guess i should have proof read it. sorry anyways i had 3 out 4 pistons have pressure. the 3 at about 100 and the 1 at 0 which is piston 1. i can also pull off the disty cables on the right side and doesnt effect the engine i hate to tell you this, but you have a tired engine. 100 psi is low, ive seen lower. a wet/dry test would tell us it its rings vs valves, but i think the point may be moot. engine compression should be 120 minimum, with 160 prefered, and no more then 10% variance betrween cylinders. Now it is possible your timing belt jumped and that would explaine the 100, but that wont explaine zero. nipper Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 29, 2006 Author Share Posted July 29, 2006 lol great, thanks for the quick feedback. so im not sure what a wet test is but im planin on pullin the engine this weekend and lookin at the valves or anything else that may be wrong. i know my oil light keeps commin on so ill probably replace the pump aswell Quote Link to comment Share on other sites More sharing options...
nipper Posted July 29, 2006 Share Posted July 29, 2006 lol great, thanks for the quick feedback. so im not sure what a wet test is but im planin on pullin the engine this weekend and lookin at the valves or anything else that may be wrong. i know my oil light keeps commin on so ill probably replace the pump aswell Why must you give me bad news? a wet test is the same as a dry but you squirt oil in the ctylinders first. Low oil pressure is not necassarly a bad oil pump, but bad bearings. This engine is very tired. nipper Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 29, 2006 Author Share Posted July 29, 2006 hmm so i should just do th ej22 in it huh.. ill tell my gf you gave me the go so i can do it hehe Quote Link to comment Share on other sites More sharing options...
nipper Posted July 29, 2006 Share Posted July 29, 2006 hmm so i should just do th ej22 in it huh.. ill tell my gf you gave me the go so i can do it hehe tell her in the long fun your better off, as the car may throw a rod otherside, especially after putting all that work into it, how many miles on this puppy? Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 29, 2006 Author Share Posted July 29, 2006 almost 200000. it drove like a champ till about a week ago i sank the engine in a mud hole/pond oh and the hubs are out they grind so bad just havent had time to do it Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 29, 2006 Share Posted July 29, 2006 Sounds like the head gasket let go on cylinder #1. Being an EA81 you have no belts, so valve timing is not an issue. A reading of 0 pretty much rules out rings, and unless a valve is stuck (unlikely) it's the head gasket. I've seen plenty of EA81 and EA82 engines that lost compression in just one cylinder. It's usually overheating that blows them from a coolant passage into the combustion chamber. Bought a wagon like that and was able to drive it 30 miles home stopping to check the coolant level a few times - even got it up to 60 MPH with three cylinders - compression was 0 on cylinder #3. Replaced that gasket and it was fine after that. Sinking it in a mudhole is BAD - did the engine flood out? I did that one too many times to the engine in my wagon, which when I started was in very good shape and only 145k on it. Only 20k later and my lack of replacing the oil pump, and too many dips into the swamp water did the rod bearings in - even with frequent oil changes. I blew one doing 75 MPH on the freeway. 200k is not "tired" for an EA81 unless it's been badly maintained (sounds plausible in your case). Your lack of oil pressure is disturbing, and I fear that even if you do the head gasket that at this point your bottom end may be so damaged that it would be a waste of time and effort. GD Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted July 29, 2006 Author Share Posted July 29, 2006 ok thanks for another opinion. im just gonna take it out check things out down at dhm . dave at dhm subaru my best friends dad hes been working on subaru almost as long as i been alive. west coast people might know him. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 29, 2006 Share Posted July 29, 2006 Sinking it in a mudhole is BAD - did the engine flood out? I did that one too many times to the engine in my wagon, which when I started was in very good shape and only 145k on it. Only 20k later and my lack of replacing the oil pump, and too many dips into the swamp water did the rod bearings in - even with frequent oil changes. I blew one doing 75 MPH on the freeway. 200k is not "tired" for an EA81 unless it's been badly maintained (sounds plausible in your case). Your lack of oil pressure is disturbing, and I fear that even if you do the head gasket that at this point your bottom end may be so damaged that it would be a waste of time and effort. GD maybe i should have used the word, beat. i dont know if subarus that are well maintained ever get tired, but compression that low is a tired engine. i know its rare for the bottom end ot og bad, but adding up all the symptons, sounds like its had a rough life. Good luck. nipper Quote Link to comment Share on other sites More sharing options...
