Can I do this?
Hello i have a 86 wagon carb motor and i have a 87 turbo motor can i swap if i change the harness and comp?
yep. do a search in the the retrofitting forum for more info
ohh... WELCOME TO THE FORUm..
Where are my manners...
bW
bW
Hey Thanks
I sure like this site have good one
Which way are you swapping? If turbo into carb chassis, it is far more complicated. Starting at the back and moving forward: Swap Fuel pump, swap fuel lines (FI is higher pressure and requires a high-volume return line), ECU, wiring, engine w/exhaust up- and down-pipes, engine crossmember. If you are planning on using the turbo's tranny you swill also need its axles. Probably a few other things that I have missed.
Aren't turbo difs a different ratio from a N/A dif?
If manual, yes. If auto, I don't think so (?).
However, the author of this thread doesn't mention switching trannies. The difference is in the tranny.
