ea82 fuel injected
Rip
Only made a single point carb'd intake. Why do you want to go carb btw?
My car is a singal port carb motor and i ordered a motor and it came as fuel injected turbo and i thought the intakes would interchange and they want and now the company want take the motor back and i got a motor that want fit the car talk about learning the hard way.
You might consider recouping your costs by selling off the engine. EBAY or Craigslist are 2 options. How much do you have into the engine?
I bought it from one of those Japanese motor imports looks like almost new real clean turbo down and i paid $ 650.00 for the motor and new timing belts.
You *could* change the heads, but then that leaves with the lower compression turbo pistons too...
That sucks man.
i thought the heads was what determined the compression is that not true on this motor?
You're only about 100 miles away from me. I may be able to help scrounge up a carb motor locally.
What kind of money do you think we would be looking at? heck i wish i could find another turbo 4wd car at this point i need it to go to colorado in two weeks.
All the heads have the same combustion chamber, so no. What determines compression is the pistons. Turbo pistons have a bathtub cut into the top of them, making them 7.7:1 instead of the carb's 9.0:1
