TD04/Delta 272 CAM Install complete!
It's been awhile but I've got it all done and have been driving it for the last few weeks.
I got the TD04-13g Turbo installed onto my modified up-pipe, used a Stock WRX Downpipe and had to slightly clearance the lower crossmember to get it not to rub while going down the road, I got the Delta 272 cams and I love the extended power band I got with them, pulls hard from 3k to 7k :)
The only thing that sucks about the 272 cams is the lifter clearance changes allot, and finding the right shim to make up the difference is a PITA!!!!!!! The shims they sent me didnt work and ended up cracking about a few miles and the ticking would get worse as they would flatten, so I used a combination of DIMES and some other SS Flat Washers that were thicker, the result is much quieter valve noise but still ticks a bit, but not nearly as bad as before, so I'm going to live with it for now since I have yanked the CAM Cases 5 times allready to adjust them!!!!! :mad:
All in all the car is a beast and I have yet to loose to anyone!
So far I'm running 10psi of boost and the thing just begs for more, I will keep everyone updated and hopefully I will be at WCSS 8!
Enjoy
Kill List so Far :
Nissan 350Z 6-speed (5 cars from a 30mph roll)
Subaru WRX 5-speed w/I/H/E/16psi (3 cars from a 45mph roll)
00' Honda Civic SI 5-speed w/I/H/E (im sure you can guess LOL)
80's Subaru GL Turbo Wagon (not even close, hehe)
3c6d585ceb18.jpg?_rh=8i8vgwqxyet13arowhgctu8qj
6561dc3d8e9a.jpg?_rh=4gxjzeks931g8yuxhanck8k1m
Nice! are you running a boost controller or is stock boost on the TD04-13G wastegate 10psi ?
I'm welding my up pipe and down pipe today or tomorrow so I'll have my TD04L on and ready to go for WCSS 8 perhaps we'll have to find some open highway on the way there or back :burnout::grin:
Mine will be put back together this weekend, YAY!
I'll be running the 260 cams from Delta with a high compression SPFI block, TD04, IC and a lot of other goodies as well. Too bad I won't be able to make it to the show this year. Kinda a far drive for me and couldn't get the time off approved. Next year though, I'll be there. :banana:
