miken6qzt Posted August 5, 2006 Share Posted August 5, 2006 I have an 85 4wd turbo wagon. I need to remove the windshield washer fluid container in the right front fender. How do I go about doing it.:cool: Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 6, 2006 Share Posted August 6, 2006 Sorry to be the one to tell you, but you pretty much have to remove the fender. You may be able to get to it from the wheel well if you pull down the plastic mud guard, but I'm not sure. GD Link to comment Share on other sites More sharing options...
Tom63050 Posted August 6, 2006 Share Posted August 6, 2006 Sorry to be the one to tell you, but you pretty much have to remove the fender. You may be able to get to it from the wheel well if you pull down the plastic mud guard, but I'm not sure. GD Yeah, remove the fender. It's actually pretty straightforward. Link to comment Share on other sites More sharing options...
daeron Posted August 6, 2006 Share Posted August 6, 2006 that blows... does this apply to my 87 GL10 sedan as well? it would seem to, but i have never looked at it with the thought of removing it, so i couldnt tell you what it looks like... Link to comment Share on other sites More sharing options...
miken6qzt Posted August 12, 2006 Author Share Posted August 12, 2006 that blows... does this apply to my 87 GL10 sedan as well? it would seem to, but i have never looked at it with the thought of removing it, so i couldnt tell you what it looks like... Thank's everyone, I'll bite the bullet, and get to it. Mike Link to comment Share on other sites More sharing options...
nkx Posted August 13, 2006 Share Posted August 13, 2006 i would remove the fender liner first. i think theres 2 bolts holding the tank in. removing the fender itself will provide the most room to work with, but you have to pull the bumper to get the front of the fender off. (which is always PITA in my experience.) Link to comment Share on other sites More sharing options...
TomRhere Posted August 13, 2006 Share Posted August 13, 2006 Got an '86 Sedan here that I'm stipping for parts. I have the fenders off of it, but it does look like you could drop the tank out from the bottom if you pull the plastic liner in the wheel well. Link to comment Share on other sites More sharing options...
moshem74 Posted August 13, 2006 Share Posted August 13, 2006 you just need to take out the thing that is under the fender, the black thing that on the wheel, 6 screw's and 15min and it's out, you dont need to take the wheel out. Link to comment Share on other sites More sharing options...
calebz Posted August 13, 2006 Share Posted August 13, 2006 I pulled mine when I did removed the air intake snorkus. Took a few minutes to find all the bolts, but it wasn't super hard. Just removed the wheel and the plastic fenderwell lining. Link to comment Share on other sites More sharing options...
nkx Posted August 14, 2006 Share Posted August 14, 2006 ok, i checked it out today. theres 3 nuts/bolts, accessed from the engine bay side. undo those, and you should be able to slide the resevoir out without needing to take off the fender. Link to comment Share on other sites More sharing options...
miken6qzt Posted August 18, 2006 Author Share Posted August 18, 2006 Hi Everyone, OK, I went in through the front liner. There are 3 studs that stick through the fender. 2 behind the drier, and 1 behind the air cleaner. The liner came out quickly, and easily and the unit was replaced smoothly. It all happened so fast that I'm still waiting for the inevitable problem to show up. Thanks for all the suggestions. Mike. Link to comment Share on other sites More sharing options...
