do you have a fan relay?
i don't.and neither does napa,or schmucks,or motion. or,or ,or ,or.so she(monstaru) got a newly resealed motor this weekend.a tad bit of a face lift and another ground wire.the only thing that is different from before as far as the motor is concerned electrically is an 8 guage ground wire.so it started yesterday on my way to work,temp rising(but not registering on guage) and no fan chiming in.get off work,go to motion,get fan thermal switch....go home,put in thermal switch and switch out water temp sensor as well.awesome.get's up to temp and fans come on,intermittent like.then eat a fusible link,and there fuse in the block.fix fusible link.completely rewire fans,and put in new fuse.no workie.i finally get them working and start blowing fuses.unplg one of them and am golden.i really like two of them.so here i sit wondering what the ************?look at ondemand,htkysa,and hanes referance.ALL STATE THAT I HAVE A RELAY!ummm,i don't.and only think i know where the plug in is for it.i realize that it is supposed to be on the passenger side strut tower.but,i have about 5 or 6 plugs on that side that go to nothing.i seem to have good luck with gremlins usually,anyone have a pic of your relay or where the hell i can get one.......cheers, brian
so i went and got a fan relay today.hooked up both fans.made sure the fans were spinning the right way(one was going opposite the other day).and it works.i don't know why.i don't even want to know why.but it does.and i am out of ************ creek.cheers,brian
