Any recommendations on good obd2 code readers for 95-99 series of legacies/outbacks? Tnx!
I know that you asked about "code readers", but are you aware of the difference between a code reader and a "scan tool"? "Code readers" do just what you'd expect from the name; inexpensive ones allow retrieval of stored trouble codes, erasing of codes, and resetting (turning off) the MIL. That can be useful, but not nearly as much so as a "scan tool".
A decent scan tool will do what a code reader will, and let you view pending codes, view "freeze frame" data, and display sensor operation in real time. Those additional things can make diagnosis a lot easier than just having a static code to interpret.
The cost of a scan tool is typically about two to three times that of a code reader, but the first time you avoid a misdiagnosis and don't change parts unnecessarily you might save the difference in price.
Bought Actron reader from PepBoys on sale; works pretty well. Would much rather have a setup that allows showing freeze frame data, etc.
Seems like I saw one that was software based (to run on laptop or other computer) with cable on eBay for same price as good reader; not sure how well it works though, plus you have to have a computer there, whereas with a self contained unit in the glove box you can plug it in no matter where you are when the code happens.
