subdoug Posted August 9, 2006 Share Posted August 9, 2006 Any recommendations on good obd2 code readers for 95-99 series of legacies/outbacks? Tnx! Link to comment Share on other sites More sharing options...
njdrsubaru Posted August 9, 2006 Share Posted August 9, 2006 i got one from pepboys and it works fine on my 95 obd2 also works with other cars Link to comment Share on other sites More sharing options...
OB99W Posted August 9, 2006 Share Posted August 9, 2006 Any recommendations on good obd2 code readers for 95-99 series of legacies/outbacks? Tnx! I know that you asked about "code readers", but are you aware of the difference between a code reader and a "scan tool"? "Code readers" do just what you'd expect from the name; inexpensive ones allow retrieval of stored trouble codes, erasing of codes, and resetting (turning off) the MIL. That can be useful, but not nearly as much so as a "scan tool". A decent scan tool will do what a code reader will, and let you view pending codes, view "freeze frame" data, and display sensor operation in real time. Those additional things can make diagnosis a lot easier than just having a static code to interpret. The cost of a scan tool is typically about two to three times that of a code reader, but the first time you avoid a misdiagnosis and don't change parts unnecessarily you might save the difference in price. Link to comment Share on other sites More sharing options...
porcupine73 Posted August 9, 2006 Share Posted August 9, 2006 Bought Actron reader from PepBoys on sale; works pretty well. Would much rather have a setup that allows showing freeze frame data, etc. Seems like I saw one that was software based (to run on laptop or other computer) with cable on eBay for same price as good reader; not sure how well it works though, plus you have to have a computer there, whereas with a self contained unit in the glove box you can plug it in no matter where you are when the code happens. Link to comment Share on other sites More sharing options...
