DIRAVI Posted August 10, 2006 Share Posted August 10, 2006 Hi, i hawe a tranny at home, from an 82 SuperStation. It seems to me that it should be Dual Range. Is thera other than 5sp dual range? What is the exterior diferense between the trannys. I planing to mount A EA82T in my 84 Hatch, and whant to uppgrade the 4sp to 5sp D/R Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted August 10, 2006 Share Posted August 10, 2006 There are a few people on here that have done the 5sp d/r swap.I believe you will need to build some mounting brackes,or I know that there is a guy on here who makes a kit to do it.Lots of good info on here for what you are trying to do.Good luck. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted August 10, 2006 Share Posted August 10, 2006 Yes, the EA81-series (and earlier) came with a dual-range 4-speed transmission. I could not tell you what the external differences are; sorry. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 10, 2006 Share Posted August 10, 2006 4 speed is longer than the 5, and heavier. GD Quote Link to comment Share on other sites More sharing options...
NorthWet Posted August 10, 2006 Share Posted August 10, 2006 My D/R 5-speed length is approximately 28.75inches (64.7cm). Quote Link to comment Share on other sites More sharing options...
MSSLGECKO Posted August 10, 2006 Share Posted August 10, 2006 There is also an AWD D/R 5 spd that came in some EA82T models (rear lsd included). Quote Link to comment Share on other sites More sharing options...
DIRAVI Posted August 10, 2006 Author Share Posted August 10, 2006 So, most probably my D/R is 4sp. I shold try to get an 5sp D/R from an EA82 car. The LSD rear whold be nice, but mayby not so easy to find. Are tere any FT4WD with Center Difflock, i prefer to be able to lock the center diff, or have a on/of style 4WD. If i get a Tranny from an EA82T car, what neds to be done whit the axels? 23/25 splines an so. Quote Link to comment Share on other sites More sharing options...
