P K Posted August 11, 2006 Share Posted August 11, 2006 Hello All, I have searched but don't have the complete detail of what I want. If someone could point me to relevent USMB threads, I would be most grateful. Situation is I want to switch transmissions between my: 82 Brat with 4 speed D/R 92 Loyale with 3AT part-time 4WD Desire to put the 3AT in the Brat, and the 4 speed (or get 5spd) in the Loyale. Don't condemn me for the blasphemy, I just need an AT Brat, and a DR wagon. Unanswered questions: 1. Do I need a lift kit to get the AT under the Brat? 2. Should I ditch the 4 spd and get a 5 spd for the Loyale? (driveshaft?) 3. Will an EA81 pedal box fit to an EA82, and vice-versa? 4. Do I need to buy an EA81 torque converter or will the EA82 fit? or can I switch flywheels too? 5. What am I forgetting - I have both complete vehicles, so any part that needs to go to the other is available. Thanks in advance, r/PK. Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted August 11, 2006 Share Posted August 11, 2006 Don't think you will need a lift to put in the A/T.I think the two pedal clusters are different so you will have to do a little switch er roo.If I think of something else I will post it. Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 11, 2006 Share Posted August 11, 2006 1. No lift needed, Brats also came with 3AT. You will need to change the radius rod plates and tranny mounts tho. 2. Yes, get a 5spd D/R for the Loyale. You will need the 2 piece driveline that comes with it. 3. Dont think the pedal boxes are the same, but might be adaptable. 4. Not sure, but I think the TC is the same. But the flexplate might be different. Easy to check tho, just slap it on and put a few bolts in. Turn the engine (by hand) and see if it rubs. 5. Dont forget the nuetral safety switchs. Quote Link to comment Share on other sites More sharing options...
