Power Steering Prob!
Leone Ea82 the power steering is not working keeps leaking from the rack down, I have changed couple of seals, still leaks all the Atf out. The steering is worse then a manual steering its hard! I think i'm not fixing some seals right or i’m missing something need help anyone have a pic or something of how the seals go basically I need power steering working.
Amk.
Is the leak coming from where the hydraulic lines thread into the rack?
Is the leak coming from inside the boots on the sides (the boots that surround the inner tie rods)?
The leak is from inside the boot the top pumps ok i removed the two lines started the car it pumps just fine but it leaks from down the Pinion if im not mistaken, but you got it leaks from the boot cover only on 1 side the hydraulic lines side.
Have you done the one under the tank on the top of the pump? Other wise there are 2 hoses and then the connections on the rack... not much to it
The top pumps fine it leaks from down the rack.
