SteelyDel Posted August 18, 2006 Share Posted August 18, 2006 Hi everyone! I replaced my front CV boots once a year I don't know why, until I checked my tranny mounts both are gone! This week's repair are- one axle needs all boots the other only the outer. And I install a pair of used tranny mounts. So (I think), my conclusion is that the tranny is just floating sideways and wreck havoc on the cvs. Are there abundant supplies of these rubber mounts somewhere for my future use? Or anyone? It's my 84 Brat. Thanks DEL Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 18, 2006 Share Posted August 18, 2006 The mounts can really hurt the joints themselves, but not really be boots. Boots are usually a result of really thin rubber boots used by rebuilders. Or in the case of the passenger side the cat not having a heat shield. Get some GCK axles and be done with axles for a LONG time (Autozone sells em). http://www.gck.com/ Urethane boots are possible too - check into the VW aftermarket.... GD Link to comment Share on other sites More sharing options...
SteelyDel Posted August 18, 2006 Author Share Posted August 18, 2006 The mounts can really hurt the joints themselves, but not really be boots. Boots are usually a result of really thin rubber boots used by rebuilders. Or in the case of the passenger side the cat not having a heat shield. Get some GCK axles and be done with axles for a LONG time (Autozone sells em). http://www.gck.com/ Urethane boots are possible too - check into the VW aftermarket.... GD I did installed a heat sheild on the catside but that boot just went too(just the metal straps left).Got the new boots from Carquest and a seem thicker than the usual NAPA products. Thanks Link to comment Share on other sites More sharing options...
mcbrat Posted August 18, 2006 Share Posted August 18, 2006 rockauto.com should have them.... http://www.ultimatesubaru.org/forum/showthread.php?t=43805&highlight=tranny+mount Link to comment Share on other sites More sharing options...
baccaruda Posted August 18, 2006 Share Posted August 18, 2006 you can get new trans mounts from the dealer ($30ish each I think, maybe less if you buy them from a USMB-friendly dealer) and sometimes for a lot less on ebay. Link to comment Share on other sites More sharing options...
