obd is the computer it stands for on board diagnostics the 96 is non interference the interference starts at 97 year model even through they were manufactered in late 96.
what is obd and what does it do?
has anyone put the older 2.2 in a newer legacy?
'95 and '96 are non-interference, OBDII (what you want.) '97 and newer are interference, meaning that the pistions will interfere with the valves if timing belt breakage occurs. Makes me cringe just thinking about it.
Is the computer hook-up just plug and play? The '99 computer will run the '95 or '96? Seems like it is by the other replies, but I really have no clue.
