OldSkoolSteve Posted August 19, 2006 Share Posted August 19, 2006 After much thought I would like to upgrade my 85 GL-10 EA82T 4wd suspension to a tighter spring and shock package. Any websites would be appreciated. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 19, 2006 Share Posted August 19, 2006 What are you trying to do? Lower it? Raise it? Better handling? Tighter as in what? Stiffer springs for handling? Lower to the ground? There really isn't any web sites for this - you have to find something that fits your application and make it work. You may have to cut some springs down, or modify the spring perches on the strut tube, etc. If you convert to 5 lug suspension using XT6 parts, you'll have a lot more options for front struts - the rear is just a coil-over and there are some accord springs that are similarly sized. GD Link to comment Share on other sites More sharing options...
OldSkoolSteve Posted August 19, 2006 Author Share Posted August 19, 2006 My wagen just feels sloppy. I would like it a little lower and tighter in handling. It has adjustable struts so I may just lower them all the way to tighten up the springs. This fall I plan on getting new shocks and an alignment so figured I might as well deal with the springs at the same time. Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 19, 2006 Share Posted August 19, 2006 might as well do a 5-lug swap since the market for suspension on the EA82s is none. Here's a link to the USRM about the conversion... http://www.ultimatesubaru.org/forum/showthread.php?t=50400 If you do a 5-lug conversion, it opens you to a lot of brake upgrades, suspension upgrades for the front, larger swaybars, rim selections, and tons more. Link to comment Share on other sites More sharing options...
The Dude Abides Posted September 28, 2007 Share Posted September 28, 2007 Caboobaroo said: might as well do a 5-lug swap since the market for suspension on the EA82s is none. Here's a link to the USRM about the conversion...http://www.ultimatesubaru.org/forum/showthread.php?t=50400 If you do a 5-lug conversion, it opens you to a lot of brake upgrades, suspension upgrades for the front, larger swaybars, rim selections, and tons more. but that involves also buying all the 5 lug swap stuff and 5 lug wheels and tires. for those who have not as much money but would still like something nice. ive heard miata shocks ive heart accord springs. equal lowering on all 4 corners 1 inch up front 1 1/2 or so in rear. ill buy new shocks i just dont know what springs to put on. if u use miata struts can u use the springs. Ben Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 29, 2007 Share Posted September 29, 2007 For cheap upgrade, see if you can find an old RX at the bone yard and grab the front springs. They are stiffer than the regular GL's and improved the handling on my 87 GL-10 quite a bit. And yes, do get new struts. I've not heard of using Miata springs. Is there a link to that mod? Did they make the 4 speed A/T in 85? I thought those were added in 88? Mine had the crappy 3 speed, which I swapped out for a 5 speed FT4WD. Link to comment Share on other sites More sharing options...
Numbchux Posted September 29, 2007 Share Posted September 29, 2007 The Dude Abides said: but that involves also buying all the 5 lug swap stuff and 5 lug wheels and tires. for those who have not as much money but would still like something nice. ive heard miata shocks ive heart accord springs. equal lowering on all 4 corners 1 inch up front 1 1/2 or so in rear. ill buy new shocks i just dont know what springs to put on. if u use miata struts can u use the springs. Ben 2 things... 1. this thread is more than a year old.... 2. don't be spreading lies as fact. accord front springs in the rear of an EA82 subaru LIFT the car an inch or so. and Miata FRONT shocks are about 2" longer than stock, and rears at least as much shorter. in order to run Miata rears in an EA82, you need a much stiffer spring rate (I still bottom out mine on 400lb/in coilovers adjusted as tall as they get). and the accord/miata stuff is only applicable in the rear. for a decent setup for 4-lug, without spending too much money. KYB GR2s, and Ground Control (or similar) coilover springs for a '93-'01 impreza. Link to comment Share on other sites More sharing options...
The Dude Abides Posted October 1, 2007 Share Posted October 1, 2007 Numbchux said: 2 things... 1. what does it matter that its old. i didnt ask old questions 2. how exactly did i spread lies and decption about the usmb you talk about useing miata stuff and i have seen people ask about the tempo springs. for a decent setup for 4-lug, without spending too much money. KYB GR2s, and Ground Control (or similar) coilover springs for a '93-'01 impreza. coilover springs ok but how will that work with a longer shock. if you tighten it down to much your going to loose decent comfortable driveability. Link to comment Share on other sites More sharing options...
WJM Posted October 1, 2007 Share Posted October 1, 2007 Here's how to make the shocks stiffer: 1. Remove from car, take them out of the springs. 2. Drill hole in bottom of shock body. 3. Drain watery shock oil. 4. Tap threads into the drilled hold so you can seal it back up. 5. Fill the shock with proper amount of desired shock oil (could be engine oil or gear oil for all I care, i used 90W gear oil with my 600lb coilover springs). 6. Install plug. 7. Install back on car w/springs and junk. 8. Happy stiffness. 9. ???????????????? 10. PROFIT!!!!!!!! Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 1, 2007 Share Posted October 1, 2007 WJM said: 9. ???????????????? This is the most important step right here! Link to comment Share on other sites More sharing options...
Numbchux Posted October 1, 2007 Share Posted October 1, 2007 The Dude Abides said: coilover springs ok but how will that work with a longer shock. if you tighten it down to much your going to loose decent comfortable driveability. your driveability won't change until you bottom out the shocks.....and with stiffer springs you can easily run 2-3" lower than stock without risking that. in the back, you'll ride on the bump stops long before you actually bottom out the shocks. if you're going for some extreme lowering, THEN you should switch to 2WD XT struts and miata rear shocks. but these (especially the miata stuff) will require at least 3" of drop since I can't afford the AGX's this fall, I intend to try the WJM patented shock/strut fluid change. but I think it'll make quick work of the seals on my daily driven car Link to comment Share on other sites More sharing options...
WJM Posted October 1, 2007 Share Posted October 1, 2007 I didnt have any problem with my seals...unless the shock was over filled. Link to comment Share on other sites More sharing options...
The Dude Abides Posted October 6, 2007 Share Posted October 6, 2007 WJM said: Here's how to make the shocks stiffer: 1. Remove from car, take them out of the springs. 2. Drill hole in bottom of shock body. 3. Drain watery shock oil. 4. Tap threads into the drilled hold so you can seal it back up. 5. Fill the shock with proper amount of desired shock oil (could be engine oil or gear oil for all I care, i used 90W gear oil with my 600lb coilover springs). 6. Install plug. 7. Install back on car w/springs and junk. 8. Happy stiffness. 9. ???????????????? 10. PROFIT!!!!!!!! i only wish i had underpants nombs to fix my car Ben Link to comment Share on other sites More sharing options...
