matts87glsedan Posted August 19, 2006 Share Posted August 19, 2006 car has been sitting with exhaust pipes off for several days. im under it this morning putting everything back together after my nightmare clutch job, and i see this coolant drip, coming out the driver side exhaust port. Could someone break the bad news to me and describe whats going on with that? Link to comment Share on other sites More sharing options...
Manarius Posted August 19, 2006 Share Posted August 19, 2006 Smells like headgasket to me. Link to comment Share on other sites More sharing options...
rllywgn Posted August 19, 2006 Share Posted August 19, 2006 if its coming out the exhaust port, it's likely a cracked head.. aluminum head rebuilders in portland, oregon has pretty good deals on reman'ed heads rllywgn Link to comment Share on other sites More sharing options...
GLCraig Posted August 19, 2006 Share Posted August 19, 2006 If it's a EA82T with Gen1 or Gen2 heads, it's probably a crack in the head where the exhaust runners converge together in the exhaust port. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 19, 2006 Share Posted August 19, 2006 Do a pressure test - if you had the engine out, or pulled forward coolant might have just dripped down to that area. The non-turbo's don't usually crack like the EA82T's.... GD Link to comment Share on other sites More sharing options...
NorthWet Posted August 20, 2006 Share Posted August 20, 2006 Is it coming out the port or just down the stud? Stud could be anything leaking. If it is coming out of the port it could be intake manifold gasket. As GD typed, exhaust-port crack is unlikely unless MPFI/turbo head. Link to comment Share on other sites More sharing options...
matts87glsedan Posted August 20, 2006 Author Share Posted August 20, 2006 sweet, thanks for the replies. it was definitely leaking out of the exhaust port itself (but ive also got burned off coolant on top of the engine). this is a non turbo, i dont know the diff between gen 1 and gen 2 heads. its had this leak for about 5000k's, and its been warmed up several times, but never quite into the red. I'm pretty sure that the intake manifold gasket is leaking , but i was wondering if it could be worse than that. Link to comment Share on other sites More sharing options...
matts87glsedan Posted August 20, 2006 Author Share Posted August 20, 2006 on the upside, the clutch is in, and test driven. total elapsed time... 5 days. Link to comment Share on other sites More sharing options...
4x4_Welder Posted August 20, 2006 Share Posted August 20, 2006 I dunno, my very first Subaru was an 89 GL wagon, didn't even get to drive it on the road. Bought with a supposed bad head gasket, pulled the heads and found both severely cracked from valve stem to valve stem. Does it actually burn coolant at all, and does it misfire? Link to comment Share on other sites More sharing options...
matts87glsedan Posted August 20, 2006 Author Share Posted August 20, 2006 well, i dont know if its burning coolant, i know its cooking on the top of the block and heads. how would i know? like white smoke out the pipe or something? there was white residue inside the pipe at the head, a bit more noticeable on the driver/problem side. it has started to idle more roughly now, in the last week. I was driving up a smallish mtn pass last week(like a mile of not too steep), and my friend behind me commented that he could smell coolant, which didnt suprise me because ive been losing it for a while now . i just thought it was burnin off the top. Link to comment Share on other sites More sharing options...
matts87glsedan Posted August 20, 2006 Author Share Posted August 20, 2006 oh ya. no it doesnt misfire at all. still runs quite well, but idles a little rougher - like i was sayin. Link to comment Share on other sites More sharing options...
