jonfit04 Posted August 20, 2006 Share Posted August 20, 2006 I have 1999 Subaru Impreza Outback Sport AWD 190,000 miles 2.2lt...anywho..I had the CEL go off and the PCM at autozone read....Knock Sensor Malfunction in Bank 1....so I go ahead and purchase a new Knock Sensor...take the old one off and put the new one on.....AS soon as I started the car with the new one ...the Engine Missed and carried on, would not go at all...SO i took it off and cleaned the block with steel wool and put it back on....still the same...so i took the old one and cleaned it with steel wool and....it is running just fine....CEL Still on ..but no more missing and timing problems. ...So did I solve the problem or not....anyone have any suggestions? Thanks Jon Link to comment Share on other sites More sharing options...
brus brother Posted August 20, 2006 Share Posted August 20, 2006 You didn't say if there were any performance issues initially. Clear the code and see if it comes back? jonfit04 said: I have 1999 Subaru Impreza Outback Sport AWD 190,000 miles 2.2lt...anywho..I had the CEL go off and the PCM at autozone read....Knock Sensor Malfunction in Bank 1....so I go ahead and purchase a new Knock Sensor...take the old one off and put the new one on.....AS soon as I started the car with the new one ...the Engine Missed and carried on, would not go at all...SO i took it off and cleaned the block with steel wool and put it back on....still the same...so i took the old one and cleaned it with steel wool and....it is running just fine....CEL Still on ..but no more missing and timing problems. ...So did I solve the problem or not....anyone have any suggestions? Thanks Jon Link to comment Share on other sites More sharing options...
jonfit04 Posted August 20, 2006 Author Share Posted August 20, 2006 Oh I did forget to mention that....there was issues before I bought the new part...If I was going up hill the light would come on and the car would shutter and then wouldn't go very fast. and then eventually it would go back to normal in a matter of minutes....really it didnt only do it on hills...it would do it pretty much anytime. so when the light came on i drove straight to autozone and had them read the computer. Also another question I have the keyless entry on this car...but the remote doesnt work..I thought it was the remote battery so I bought a new one....but no luck..now I know there is an overide programming button on the car below the steering wheel...but I believe someone has removied it from the car....because its missing...is there any way to replace that...or get the programming to work any other way? Link to comment Share on other sites More sharing options...
porcupine73 Posted August 20, 2006 Share Posted August 20, 2006 Sounds like your knock sensor might be a little too sensitive, or you have some engine condition causing a lot of knock. It also sounds like maybe the aftermarket knock sensor might not have matched OE specs completely. Could maybe try going up a hill with the knock sensor disconnected and see if it acts up. For the remote, you might just have to 'program' your vehicle to recognize that remote's code; check the manual. Link to comment Share on other sites More sharing options...
jonfit04 Posted August 21, 2006 Author Share Posted August 21, 2006 Ok, Well whatever was wrong with the knock sensor is now fixed, No problems so far. I am still wanting to get the keyless entry working...the only thing I can find in the manual is that I need to press the overide programming button...problem is that the button is not there? HELP? Link to comment Share on other sites More sharing options...
Sweet82 Posted August 21, 2006 Share Posted August 21, 2006 jonfit04 said: Ok, Well whatever was wrong with the knock sensor is now fixed, No problems so far. I am still wanting to get the keyless entry working...the only thing I can find in the manual is that I need to press the overide programming button...problem is that the button is not there? HELP? Time for a new thread on Keyless entrys..... I have a new Subaru 01-02 entry system (plug and play) due to arrive in the mail any day now. I'm looking to sell it...CHEAP! I purchased it just for the remotes. Oh ya, I had the same "knock sensor bank 1 malfunction" code last week. Cleared it and it has not reared it's ugly head again...so far... Link to comment Share on other sites More sharing options...
spyder550 Posted August 21, 2006 Share Posted August 21, 2006 Have had the knock sensor problem on my N/A Impreza Sport over here in the UK. Seems very common quite a few of the guys on http://www.Imprezasport.net have had the problem too Normally seems to be a overly sensitive knock sensor, trying moving it as per the photo below. Worked on mine Link to comment Share on other sites More sharing options...
Manarius Posted August 21, 2006 Share Posted August 21, 2006 I've had two cars now with bum knock sensors and neither had crappy driving on account of it. My car's was broke for ages and no issues and a friend with a 97 had her's completely cut from the ECU and the car didn't carry on. I definitely think there are deeper issues here - knock sensors aren't that effective on how the engine runs. Link to comment Share on other sites More sharing options...
Sweet82 Posted August 25, 2006 Share Posted August 25, 2006 I was getting an 0325 Knock sensor malfunction bank one. I relocated my knock sensor and the light went back off. I'm waiting to see if it will come back... Link to comment Share on other sites More sharing options...
Gene J Posted August 26, 2006 Share Posted August 26, 2006 I had a bad Knock Sensor once and the ECM pulled a lot of timing to save the engine. It lost a lot of power and the mileage went to heck. It made a difference. Link to comment Share on other sites More sharing options...
Manarius Posted August 26, 2006 Share Posted August 26, 2006 Gene J said: I had a bad Knock Sensor once and the ECM pulled a lot of timing to save the engine. It lost a lot of power and the mileage went to heck. It made a difference. Well, the 97 did feel a bit underpowered, but it didn't carry on as this person describes. Link to comment Share on other sites More sharing options...
Gene J Posted August 26, 2006 Share Posted August 26, 2006 Manarius said: Well, the 97 did feel a bit underpowered, but it didn't carry on as this person describes.The mileage went from 22 to 18. The power was down and I could notice. But my wife didn't notice any difference. You must press the gas pedal to be able to tell. Link to comment Share on other sites More sharing options...
