painted headlights, on a 92 legacy?
as for how i did it:
i took the grill off then the headlights out of the car (two 10mm nuts, one 10mm bolt)
take the bulb out (i didint know if it would have died in ovan or not)
there are 4 little clips on the headlights around the edge, pop those off
preheat the ovan to 200*F
once the ovan is ready put the light on a cookie tray and put then in for 15 mins.
once the times up take them out (they will be hot! lol) and slowly pry the clear lens away from the rest of the light (i found it helps if you sort of cut the glue as they pull away or else you will get little glue strings every where)
once they have cooled down mask of the the center area
for paint i used gloss black since its all i had
let it dry then try to push the lens back onto the head light a little bit so they stick together (they wont be sealed at this point)
pop them back into the ovan for about 5-10 mins to heat them up enought that you can press the lens back onto the headlight and put the little clips back on
there you go, it was pretty simple and turned out great
incase any thing happens to your headlights dont come crying to me for a new pair! lol
nice write up, but i dont know if i like the idea of my lamps not being sealed anymore.. i wonder what it would be like if i painted them the same hunter green my car is ... that would be interesting
if you do the corners, can you post some pics of the process, as well as the after shots...
thanks!!
