OldSkoolSteve Posted August 23, 2006 Share Posted August 23, 2006 Where to do it? I swaped motors from a standard to auto so I need to up the idle to 9 in park. All I have is a ********************* hanes manual that "forgot" to include this. Thanks. Link to comment Share on other sites More sharing options...
Durania Posted August 23, 2006 Share Posted August 23, 2006 I have never heard of an idle adjust on a fuel injected car. On my tacoma and EJ22 legacy there is a sticker underneath the hood that says:"Computer controlled and non-adjustable". Link to comment Share on other sites More sharing options...
Petersubaru Posted August 23, 2006 Share Posted August 23, 2006 in the center area, on the back side of the throttle body is a screw (pointing downward /flat head screw driver...turn it either way as desired...I would suggest that you count the TURNS to bottom it out, then back the screw out completely to clean it up and also shoot some cleaner into the plenum...put screw back and take it from there... OldSkoolSteve said: Where to do it? I swaped motors from a standard to auto so I need to up the idle to 9 in park. All I have is a ********************* hanes manual that "forgot" to include this.Thanks. Link to comment Share on other sites More sharing options...
