michaelbteam Posted August 24, 2006 Share Posted August 24, 2006 I had to fix my leaky oil pump on the 95 Outback wagon, so I replaced the camshaft and crank seals while I was in there, and put in a "newer" water pump from a wreck, $10, also two pulleys for $5 each! [also newer covers for cheap, since the nuts broke on mine during removal] The timing belt and tensioner seemed fine so I reused those. Since it isn't an interference engine I'm willing to experiment with used parts and a little of my time and save some bucks. With my smaller 12 volt Makita I carefully drilled pilot holes into the cam seals [radiator out] for small screws, and easily pulled the seals. After screwing up the first timing belt attempt, I think when I installed the tensioner, the car ran but rough. Went back in and was very careful the second time. The question: how "dead on" should the crank and camshaft marks be at their 12 o'clock marks? On the left [driver's] side I'm off by maybe 3 sixteenths inch, and belt teeth are 5 sixteenths apart. The engine runs smoothly, but after perusing the forum perhaps I'm a little paranoid. I'm thinking this deviation might be due to the used belt stretching. How much can a belt stretch before it's useless [not broken]. Any thoughts? And thanks for the invaluable wealth of info being shared here, wish I'd found it sooner. : Link to comment Share on other sites More sharing options...
cookie Posted August 24, 2006 Share Posted August 24, 2006 Sounds normal to me. Belts don't tend to set up as precisely as gears or chains and often adjust a bit at the first running. Usually if it is off the engine does not run well. Link to comment Share on other sites More sharing options...
porcupine73 Posted August 24, 2006 Share Posted August 24, 2006 I haven't worked on that early a Suby yet, but I just did timing belt on '00OBW, and I aligned the cam sprocket marks (not arrows) with the locations indicated in the service manual, which on the LH side was a notch in the back timing belt cover. I think it is almost exactly 12 o'clock position, but the manual said align with indicated marks. Link to comment Share on other sites More sharing options...
