njdrsubaru Posted August 27, 2006 Share Posted August 27, 2006 ok i got a new toy and it fits perfectly, the connections that comes with it, plugs right into the harness of the car radio, while sharing the same harness you cancontroll the brightness of the light too, oh yeah its the gauge pack for the forester, part number H5010FC001. take a look and gime your comments, also i have included my red lighting gauges EDIT: of course it is installed on my legacy wagon cheers Neo Link to comment Share on other sites More sharing options...
ericem Posted August 27, 2006 Share Posted August 27, 2006 Cool but still not aware off what it does? Guages? What. But looks cool. Link to comment Share on other sites More sharing options...
njdrsubaru Posted August 27, 2006 Author Share Posted August 27, 2006 compass, outside temp and barometer Link to comment Share on other sites More sharing options...
ericem Posted August 27, 2006 Share Posted August 27, 2006 Thats super cool, how much do those run? Link to comment Share on other sites More sharing options...
jon38iowa Posted August 27, 2006 Share Posted August 27, 2006 compass, outside temp and barometer Yea it is cool; How hard is it to intall. I know it goes where the clam shell is on my '99 Forester, but whats involved in hooking up the electrical? John:-\ Link to comment Share on other sites More sharing options...
dmanaenk Posted August 27, 2006 Share Posted August 27, 2006 I wonder if there is a way to make it show coolant temp instead of outside one, and oil pressure instead of athmospheric Link to comment Share on other sites More sharing options...
njdrsubaru Posted August 27, 2006 Author Share Posted August 27, 2006 Thats super cool, how much do those run? its about $81 at subaru-parts-dealer.com Link to comment Share on other sites More sharing options...
njdrsubaru Posted August 27, 2006 Author Share Posted August 27, 2006 Yea it is cool; How hard is it to intall. I know it goes where the clam shell is on my '99 Forester, but whats involved in hooking up the electrical?John:-\ its not hard at all do install it comes with the harness to connect between the radio and the car, and that harness is a "plug and play", the only "difficult part" is the cable for the temp sensor in front of the car by the grill, which wasnt hard for me but it may be for some people Link to comment Share on other sites More sharing options...
jon38iowa Posted August 27, 2006 Share Posted August 27, 2006 its not hard at all do install it comes with the harness to connect between the radio and the car, and that harness is a "plug and play", the only "difficult part" is the cable for the temp sensor in front of the car by the grill, which wasnt hard for me but it may be for some people Thanks: Could you elaborate a little on the temp sensor? Do I have to run a line through the firewall all the way to the front, or is everthing already there, and all I need to do is connect it up ? Thanks in advance. John:banana: Link to comment Share on other sites More sharing options...
njdrsubaru Posted August 27, 2006 Author Share Posted August 27, 2006 Thanks:Could you elaborate a little on the temp sensor? Do I have to run a line through the firewall all the way to the front, or is everthing already there, and all I need to do is connect it up ? Thanks in advance. John:banana: Hi john Yes you have to run the supplied harness through the firewall for the sensor that goes by the grile. all you need to do is to pop the ruber plug right above the brake pedal on the firewall and that will be right under the brake booster, so just shove the wire throught there and you'll see it in the engine compartment then pull it carefully untill enought is needed to route and reach the center part of the wood latch. More info is here. this guy did it with his WRX and it works the same for us, just the unit placement for the legacies is right uner the radio. http://www.scoobymods.com/forums/archive/index.php/t-1203.html BTW it is not a major mod. to do, if you can swap radios you can do this. :-p good luck and let me know how it goes, i'll post pics of the installed harness soon cheers Neo Link to comment Share on other sites More sharing options...
