kididaho Posted August 28, 2006 Share Posted August 28, 2006 I have a 1991 Loyal wagon and need a new rear window, headlight, rack n pinion and wheels. I have a chance to buy a 1986 subaru wagon (GL, I think) parts car and wondering if the parts are interchangeable? Is there a site to find out this information or does anyone know? Thanks, Kididaho in CA Link to comment Share on other sites More sharing options...
daeron Posted August 28, 2006 Share Posted August 28, 2006 heh, provided that the intake and driveline are the same, its my understanding that virtually everything will be either identical, or interchangeable... Some parts might need to stay grouped together if you go from one to another (different brand AC compressors might need to have the bracket and mounting hardware transferred along with, etc) but they are essentially the same car. apparently it was always known as the loyale outside the US. Link to comment Share on other sites More sharing options...
NorthWet Posted August 28, 2006 Share Posted August 28, 2006 Intake/Ignition/ECU are different, some electricals are different (dashclock has a different connector). Rear hatch window and rear quarter windows are different. Major mechanicals and most bodywork is interchangeable. Link to comment Share on other sites More sharing options...
daeron Posted August 29, 2006 Share Posted August 29, 2006 why is the ignition etc different? i mean, is the 86 a carb'd model or something? i thought my post was correct, and then lookitthat, im made to look like a dummy :- ) what are the differences, or does my statement "as long as the intake and driveline are the same" stand? (IE not both SPFI vehicles...?) Link to comment Share on other sites More sharing options...
NorthWet Posted August 29, 2006 Share Posted August 29, 2006 AFAIK, SPFI was not available in 86. The distributor should be the mechanical-and-vacuum-advance kind, not the later CAS-only disty. Link to comment Share on other sites More sharing options...
daeron Posted August 29, 2006 Share Posted August 29, 2006 cool, thanks for the info. i actually just saw my first carbed EA82 in the junkyard today, i couldnt open the door to tell the year though. it had a checkered grille tho, and i nabbed it. i suppose its not a TOTAL thread jack to ask if i might be able to buy the little plastic retainer clips that the older grille screwed into as opposed to my newer setup, with the still plastic two piece screw rivet things?? the mounting points are there inside the frame for either style of grille, but i dont have the clips, they broke trying to remove them :- / Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 29, 2006 Share Posted August 29, 2006 AFAIK, SPFI was not available in 86. The distributor should be the mechanical-and-vacuum-advance kind, not the later CAS-only disty. It actually was - I thought the same till I ran across an 86 2WD GL-10 sedan at Foster the other day. SPFI - it was a little weird as far as wiring and such, but it was all there, and original. No vac can or anything. I still have doubts about 85 tho. I have seen an MPFI 85 2WD wagon though, so I think the SPFI replaced the MPFI in 86 as the standard for the 2WD high end non-turbo.... GD Link to comment Share on other sites More sharing options...
GL-10 Turbo Posted August 29, 2006 Share Posted August 29, 2006 AFAIK, SPFI was not available in 86. The distributor should be the mechanical-and-vacuum-advance kind, not the later CAS-only disty. I thought my '86 GL-10 Turbo twins (MT/AT) both had the EA-82T SPFI motors. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 29, 2006 Share Posted August 29, 2006 I thought my '86 GL-10 Turbo twins (MT/AT) both had the EA-82T SPFI motors. Turbo's are not SPFI, they are MPFI Turbo. GD Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 29, 2006 Share Posted August 29, 2006 Cool... another member from Sacramento! The body parts will fit. Most of the engine parts are interchangeable as is the interior pieces. -Brian Link to comment Share on other sites More sharing options...
kididaho Posted August 29, 2006 Author Share Posted August 29, 2006 Cool... another member from Sacramento! The body parts will fit. Most of the engine parts are interchangeable as is the interior pieces. -Brian How about the glass? I am most interested in the rear hatch window. Maybe I could just switch the whole hatch? Would that work? Link to comment Share on other sites More sharing options...
kididaho Posted August 29, 2006 Author Share Posted August 29, 2006 Thanks everyone for your help! I think I will pick up the parts cars! Link to comment Share on other sites More sharing options...
zyewdall Posted August 29, 2006 Share Posted August 29, 2006 If the '86 is a GL, it should have the dual range tranny -- stick that into the Loyale!!! Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 30, 2006 Share Posted August 30, 2006 Yes... glass, doors, hatch... everything should bolt right on. -Brian Link to comment Share on other sites More sharing options...
daeron Posted August 30, 2006 Share Posted August 30, 2006 wait wait.. didnt he say... yah Rear hatch window and rear quarter windows are different. the glass is not the same? i wouldnt know, not a wagon owner so i dont pay attention to those little details on the few wagons i have seen in junkyards.. btw it stinks not having soobs in the boneyards near me. i think i may have said that once or twice, most of us in that situation have.. Link to comment Share on other sites More sharing options...
NorthWet Posted August 30, 2006 Share Posted August 30, 2006 Just got off work, so brains/memory feel like scrambled eggs (...mmmm...), but IIRC the GLs rear hatch glass is gasketed to the hatch and the Loyale is glued. I would go out and check but it is 0-dark-thirty here. Entire hatch should interchange. Link to comment Share on other sites More sharing options...
