monstaru Posted August 31, 2006 Share Posted August 31, 2006 what do you use?this last front set was midgrade from napa and i fear are warped after 6 or so thousand miles. what do you use?and what brands are they?and what performance stats have you gathered from them?cheers,brian Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 31, 2006 Share Posted August 31, 2006 Interesting - I've not warped a set yet. I had not thought this to be a problem with the EA81 brakes..... well of course you *could* warp almost anything given the proper circumstances, but I drive my stock Brat pretty hard and haven't had any problems. I've always taken my stock rotors in and had them turned - way I figure if they are warped, then once they are turned they should be more difficult to warp a second time.... just a thought. Now I've also seen the pads wear unevenly on many of the ones I've taken apart. I think due to worn calipers or sliders. Any evidence of that? The pads wouldn't be as efficient disipating heat maybe? GD Link to comment Share on other sites More sharing options...
monstaru Posted August 31, 2006 Author Share Posted August 31, 2006 what brands do you guys use?i am obviously not a newb, so i am pretty sure they are warped.all mud cleaned ,and i am still shaking like a madman.before the show bad noises,did full brake check.all clear,obviously could not check rotors except for heat checking and what not.pads seem to have even wear,seem to have evn wear.i guess it is time to replace the whole brake system.once agian,what brands do you guys use for rotors?which are trustworthy?what aboput calipers? Link to comment Share on other sites More sharing options...
baccaruda Posted August 31, 2006 Share Posted August 31, 2006 so it only shakes when you're stopping? I'll list these thoughts anyway, you're not a n00b, but you might be goofy on those pills the dentist gave you *mud on axles *wheel bearings damaged *mud on driveshaft *tire treads not thoroughly cleaned *loose suspension components (lift blocks, struts, ball joints, etc) *gremlins Link to comment Share on other sites More sharing options...
daeron Posted August 31, 2006 Share Posted August 31, 2006 *gremlins soundin like bugs bunny there... did you know that the gremlin was invented by Roald Dahl, the wonderful man who brought us Charlie and the Chocolate Factory, James and the Giant Peach, and so many other classics... heh, i thought id make myself sound like the back of a book... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 31, 2006 Share Posted August 31, 2006 Subarus can warp rotors fairly easy given the e-brake config. Try not to use the e-brake, expecially after a long drive. The rotors will tend to cool, and if the ebrake is applied, the pressure being applied to the rotor while they cool can cause warpage. With that said, i havent used any special brand. I got a set of rotors off ebay a while ago, and they worked good. Dunno if they warped easily cause i sold that brat about 2000mi after the brake job. Just whatever Napa carries I guess... dunno what brand, never thought to check. Having your rotors turned will cost about as much as new rotors... at least, thats my experience here in CA. Not alot of shops wanna touch subaru rotors. -Brian Link to comment Share on other sites More sharing options...
