christmas22 Posted September 3, 2006 Share Posted September 3, 2006 I have a 93 loyale and a 01 impreza, and the door lock features are quite different, not sure if my 01 impreza is not working properly or thats the way it should be..here it is when I lock the car from the outside on my 93 all the doors lock, if I want to do that on my 01 I have to use the inside switch, then close the door, when I lock it from the outside only the drivers side door locks. same thing for unlocking the car. (Though I heard this is a safety feature) also on my 93 the drivers side door will not lock unless I lock it from the outside, I find this a nice feature, so I dont lock my keys in my car, though my 01 does not have that feature. it this the way it should be? Link to comment Share on other sites More sharing options...
Manarius Posted September 3, 2006 Share Posted September 3, 2006 That's the way the system on the 95 and newer cars works. Link to comment Share on other sites More sharing options...
christmas22 Posted September 3, 2006 Author Share Posted September 3, 2006 well...thats crappy, but thanks for letting me know. Link to comment Share on other sites More sharing options...
Smpol19 Posted September 3, 2006 Share Posted September 3, 2006 I went from an 89 wagon to an 01 impreza and this drove me crazy at first also. Finaly added a keyless entry unit from Crutchfield, it was less then $80 and an afternoons work installing and it didn't take 3 steaps to let passangers into the car anymore. The unit I used Link to comment Share on other sites More sharing options...
christmas22 Posted September 3, 2006 Author Share Posted September 3, 2006 thats a great idea...I think I will look into that..thanks Link to comment Share on other sites More sharing options...
ionic Posted September 3, 2006 Share Posted September 3, 2006 That's correct operation for the locks. The system changed in 97 for the Legacy and 98 for the Impreza. All Subarus prior to this had operation similar to the Loyale. I also highly recommend the keyless entry system. You can probably get one from a Subaru dealership that will "plug-n-play" on your car. This may be an easier installation than an aftermarket system, and the online Subaru dealer pricing is usually very good on these things. On the Loyale, you CAN lock the doors without using the key from the outside. Simply flip the interior lock switch to the "locked" position, then shut the door with the outside handle lifted like when you are opening the door. No need to use the key. Link to comment Share on other sites More sharing options...
Manarius Posted September 3, 2006 Share Posted September 3, 2006 ionic said: On the Loyale, you CAN lock the doors without using the key from the outside. Simply flip the interior lock switch to the "locked" position, then shut the door with the outside handle lifted like when you are opening the door. No need to use the key. Every single car I know of works like that. If you lock the door from the inside and hold the handle open as you shut the door, it will stay locked. Link to comment Share on other sites More sharing options...
outback_97 Posted September 3, 2006 Share Posted September 3, 2006 Not sure about the 01, but on my wife's 03 I ordered the keyless entry module and two remotes for $65. Installed them literally while I waited in line at the car wash. Very very easy. It was already wired for it, just plug in and go. The dealership wanted something like $400 to install this same thing Steve Link to comment Share on other sites More sharing options...
christmas22 Posted September 4, 2006 Author Share Posted September 4, 2006 outback_97...where did you get your keyless entry? I think this will solve all my issues with the door locks.. Link to comment Share on other sites More sharing options...
outback_97 Posted September 5, 2006 Share Posted September 5, 2006 Got mine at http://www.subarugenuineparts.com, through I'm sure there's other sources out there. Here is a link: https://www.subarugenuineparts.com/product_info.php?products_id=838 It says 1999-2001 in one spot but 1999-2000 in another, you might want to verify fitment for yours. Note that for some reason it's more expensive than for the 02/03 models. Still under $100 though, not bad. A guy I work with just bought a replacement remote for his VW which cost $180 (this is just a remote, not two remotes and the whole system)... and the dealership wanted $80 to program it. Steve Link to comment Share on other sites More sharing options...
