moosens Posted September 3, 2006 Share Posted September 3, 2006 Edited subject title early Tuesday AM 09/05/06 Please check posts further down,thanks. Searched the USRM....found nothing. 1987 turbo 4WD single range Both cables are older but very good.Might be a little sticky from sitting but I've got decent movement from both. I can't seem to get the clutch set up like I expect it to be.Doesn't return well at all.I got it a little better before I decided to call it a day. Correct me if I'm wrong,please.Is the only clutch return spring the hill holder spring? The turbo parts car I had sported a seperate return spring since his hill holder was out to lunch.I'm thinking that might be the way to go for now but really I want to do it right.And besides,that car is gone with the spring so I'd have to go buy something and right now stores are closing,etc. I've got both cables taunt and the adjustment nuts are well down the rods,not near the outer end but near the inner side so there's plenty of room for adjustment. Any help is as always,greatly appreciated. Link to comment Share on other sites More sharing options...
zyewdall Posted September 3, 2006 Share Posted September 3, 2006 Well, FWIW I had an '87 GL wagon that had the hill holder disconnected, with just another spring hooked onto the clutch fork. It felt terrible, and wouldn't return very well -- I think I had to put a bungee cord on the clutch fork to make it driveable. I put a new clutch cable in (even though the old one seemed to move okay), and it made a world of difference: felt great, still with no hookup to the hill holder. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 3, 2006 Share Posted September 3, 2006 Yes - on the HH equipped vehicles the return spring is the HH unit/cable. On the DL's without the HH, there was a beefy return spring, and the hole is there to mount it on the clutch fork of the HH vehicles too. If you do not want the HH you can just remove the cable completely and put the spring on instead. It's actually quite a dangerous feature off-road so that's what I've done with my wagon. The unit is still there, but without it's cable the unit's own return spring prevents it from activating so it does not cause any problems just hanging out there unused. GD Link to comment Share on other sites More sharing options...
pbrtcan Posted September 4, 2006 Share Posted September 4, 2006 Showing my lack of offroad experience but why is the HH dangerous while wheeling? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 4, 2006 Share Posted September 4, 2006 Situations can arise. If you NEED to roll backwards to escape a bad angle or are teetering on the edge of a roll-over the HH can prevent you from backing off quickly - releaseing the clutch will power you forward, so now you are really in a bad situation. Can't go forward, can't go backward... Not cool. And frankly if you know how to drive a clutch, it's just an extra bit of junk to break. Not to mention the same effect can be had with your hand brake. It's a cute selling feature to get some low income kid to learn a stick.... buy our stick, it will be easy to learn to drive, and you will save a couple grand not buying brand X's automatic.... GD Link to comment Share on other sites More sharing options...
mikeshoup Posted September 4, 2006 Share Posted September 4, 2006 Parking Break also works as a hill holder That's what I use on steep hills. Push the button in, pull the parking break up, let the clutch out until it just starts grab, and drop the brake. Off you go. Even though the hill holder works in my wagon, and its a decent feature, I don't rely on it. There are some steep hills that it does roll back on. Link to comment Share on other sites More sharing options...
nvexplorer Posted September 5, 2006 Share Posted September 5, 2006 I have my HH adjusted so it releases just before the clutch grabs. Still holds great even on San Fran streets and the car doesn't have time to roll back once the HH disengages and the clutch engages. Link to comment Share on other sites More sharing options...
moosens Posted September 5, 2006 Author Share Posted September 5, 2006 Parking Break also works as a hill holder Thanks,but I knew that about 10 years before you were born. So,anyhow,here's something I just remembered. Skip lightened the flywheel,which causes the clutch fork to be positioned well back from its normal resting place.So now I've got a hill holder adjustment rod that is slightly short.I can't even spin a nut on it right now. I'm going to change the title of this post and see how folks with the lighter f/w have gotten by. Link to comment Share on other sites More sharing options...
moosens Posted September 13, 2006 Author Share Posted September 13, 2006 Forget the posts before this one,please. I'm looking for any experience with the lightened flywheel,where the clutch fork sits with the lite f/w,and how to get the hill holder adj. rod to pass through the pin with enough space to spin a nut or two on. Thanks. Link to comment Share on other sites More sharing options...
joostvdw Posted September 15, 2006 Share Posted September 15, 2006 can't you saw off a bit of HH rod, use a coupling-rnut (or what you might call it), and a fresh LONGER bit of rod from the hardware store? if you don't trust it to stay put, use some locktite, it will never come off Link to comment Share on other sites More sharing options...
baccaruda Posted September 15, 2006 Share Posted September 15, 2006 that's a good idea.. altering the bracket to fit closer or further is another option. Link to comment Share on other sites More sharing options...
moosens Posted September 15, 2006 Author Share Posted September 15, 2006 hmmmmmm,might work if I can get a coupling small enough to fit through the pin. Hey,what if I bent the bracket back on top of the bell housing?Or shim that bracket out further rearward.Maybe I can get just enough travel out of that. I've had no time to even look at it.Let me see if that works for plan A.Plan B will be the coupling idea. Link to comment Share on other sites More sharing options...
daeron Posted September 16, 2006 Share Posted September 16, 2006 might the adjuster bolt/pin in question be different lengths on different soobs? ive never seen one as i have an auto, but it sounds like your standard linkage issue to me :- ) look things over carefully and picture them functioning in your mind to make sure you are achieving proper gemoetry with whatever you bend or alter. you might also want to take two of the rods, and cut one off rather low, so that the splicer doesnt need to pass thru anything. IE, instead of just spinning a splice nut onto the end of the one bolt and then adding an extension there, cut the bolt shorter so the splice never has to pass thru this collar youre talking about? you get my idea? not sure if its coming across too clear. from what ive heard, i would disable the hill holder on it if it were my car.. but if it were my car it would be driving around flat florida. call me biased. Link to comment Share on other sites More sharing options...
moosens Posted September 16, 2006 Author Share Posted September 16, 2006 Thanks,and yes I understand what you mean.I really don't have a lot of time for running around and finding a coupling and all,but I'll let see how it goes tomorrow. I think I might have solved my own problem.Let me see how shimming the bracket out does.A couple of washers should get me just enough thread to catch a nut or two. but it sounds like your standard linkage issue to me :- ) Not exactly.You see when you lighten a flywheel it causes the clutch fork to be placed more rearward.The clutch is adjusted really nicely right now. This car is really nice for this area,so I prefer to try to keep it 100% intact.Only 5 more year untill it's vintage. Link to comment Share on other sites More sharing options...
daeron Posted September 16, 2006 Share Posted September 16, 2006 i guess i hear you on the all original... good luck with the fabbing. nothing says loving like parts that dont fit like they did in your head... Link to comment Share on other sites More sharing options...
