Mikevan10 Posted September 4, 2006 Share Posted September 4, 2006 On a 1997 Legacy 2.2. I only have a Haynes manual and I do not see where they tell you exactly which relay is the "Main" relay. I am ASSUMING it is in the fuse/relay box under the hood on the driver's side, but even that may be wrong. Can someone pin point this for me please? Thanks! Mike V Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 4, 2006 Share Posted September 4, 2006 There is a Main Fan relay in the fuse panel located in the passenger compartment. Looking at the panel with the fuses on the left side of the panel there are 3 relays stacked vertically. The Main Fan relay is the bottom one. Quote Link to comment Share on other sites More sharing options...
Mikevan10 Posted September 4, 2006 Author Share Posted September 4, 2006 No, I don't believe I am looking for a fan relay. Looking for the one that controls power to the Evap. sys. vent/purge control valve. Any other suggestions? Thanks, Mike V Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 4, 2006 Share Posted September 4, 2006 Mike, My info shows there is a main relay (also could be called the ignition relay possibly in years past) under the dash near the driver's door area. There are a lot other things there also. Look for a brown relay socket. That should be it. Glen Quote Link to comment Share on other sites More sharing options...
Mikevan10 Posted September 4, 2006 Author Share Posted September 4, 2006 Thanks Coug! From your comments I was able to loacte the relevant relay and verify I had the correct one by identifying the wire colors. Anyway, I tested this relay and it checks out fine: contacts are open when coil is deenergized and both pairs of contacts close (less than 1 ohm resistance) when the coil is energized. And the contacts faithfully open and close when coil is energized and deenergized. So my evap. sys. vent control malfuntion (P0446) must be elsewhere. At this point, it is looking like the problem is in the ECU itself! Very frustrating. Thanks again, Mike V. Quote Link to comment Share on other sites More sharing options...
sea#3 Posted September 4, 2006 Share Posted September 4, 2006 This may help you SEA#3 Quote Link to comment Share on other sites More sharing options...
Mikevan10 Posted September 5, 2006 Author Share Posted September 5, 2006 Thanks C3! Yeah, I found the "Main Relay" up to the left of the driver's feet and I did notice the round realy in the same vicinity which I now know must be the fuel pump realy. Good info. Thanks again. Need to get one of them factory manuals. Hopefully I have one on the way to me. Mike V. Quote Link to comment Share on other sites More sharing options...
