jamman Posted September 5, 2006 Share Posted September 5, 2006 I have a 1981 GL hatchback and wanted to know if the 2 front seats are interchangable from left to right or not. Thanks in advance! JM Link to comment Share on other sites More sharing options...
SuperBrat Posted September 5, 2006 Share Posted September 5, 2006 I have a 1981 GL hatchback and wanted to know if the 2 front seats are interchangable from left to right or not. Thanks in advance! JM I ve put the passenger seat on the drivers side if that what your asking, you got to put:banana: the track from your old drivers seat on the passenger seat, but your lever will be on the right side of seat to tilt the seat back or forward.. Link to comment Share on other sites More sharing options...
jamman Posted September 6, 2006 Author Share Posted September 6, 2006 I ve put the passenger seat on the drivers side if that what your asking, you got to put:banana: the track from your old drivers seat on the passenger seat, but your lever will be on the right side of seat to tilt the seat back or forward.. Thanks for the reply! Just to make sure I am reading you correctly, you mean that the tracks need to be switched as well as the seats because they are specific to each other? JM Link to comment Share on other sites More sharing options...
jamman Posted September 18, 2006 Author Share Posted September 18, 2006 Thanks for the reply! Just to make sure I am reading you correctly, you mean that the tracks need to be switched as well as the seats because they are specific to each other? JM Just as an update, these seats are NOT interchangeable. The back inside bolt hole is specific to the side that it is on. JM Link to comment Share on other sites More sharing options...
75subie Posted September 18, 2006 Share Posted September 18, 2006 its alright to leave only one bolt out. whats the worst that could happen? i used a pass. side seat in the drivers side of mine, just switched the tracks. the seatback lever is gonna gouge the heck out of your console tho. its worth it if you have a torn up drivers seat, but a good pass side spare seat Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 18, 2006 Share Posted September 18, 2006 You can swap just the foam and cover easily. Just undo the hog-rings, and replace them with zip ties on the new seat's frame. GD Link to comment Share on other sites More sharing options...
