bgd73 Posted September 6, 2006 Share Posted September 6, 2006 I went to cars101.com and it helped. It has happened to me twice, the odd duck soob,and there is a third odd duck sitting up the road... First was a 1987 DL. the thumpiest high comp soob with factory numbers of 8.5:1 - never encountered again, even the same models same year and miles to compare to. It also ran air cooled for a summer with no overheats. I haven't seen one do it again. The back end rode like a truck, and would 3 wheel it before it gave in enough to be dynamical. Was it some kind of japanese truck version? the heads had 2 crazy pipes climbing out from underneath into a recycle gadget that always stayed cool and even gave it more power. I haven't seen it again... Second. my present 93 loyale is the last 2wd with the highest compression ever on an ea82 (9.5:1).. it is the only soob I have ever had where thoughts of slowing down occur frequently, and had it in triple digits on the highway mph.I have blown the exhaust off like an old v8 would through the seasons if 10:1 was the compression.the numbers for total sales at cars101 makes it a rare item where I live... and for the world for that matter. the third, also with info found at cars101 is a 1988 mpfi turbo wagon. It is supposedly the lowest compression for a turbo ever by subaru (just one year- and this one was it.) Does anyone have accurate ea82 production/sales info for different models, I am guessing at the three I have owned/interested in . I know odd ones exist, especially with the gl's and strange things you may find oem. I am wondering if they kept playing around with options right to the end of production, and didn't really put advertising public knowledge into it. Cars101 is a great source BTW, I am hoping to get even more specific.thanks for help Link to comment Share on other sites More sharing options...
idosubaru Posted September 6, 2006 Share Posted September 6, 2006 It is supposedly the lowest compression for a turbo ever by subaru (just one year- and this one was it.) i thought every EA82T piston was identical? 7.7:1 compression. Link to comment Share on other sites More sharing options...
bgd73 Posted September 6, 2006 Author Share Posted September 6, 2006 i thought every EA82T piston was identical? 7.7:1 compression. that is what I was hoping.I am assuming cars101 is wrong? or there really is yet another odd one.for 1988 listed: 1.8L water cooled turbocharger, 4 cyl OHC; compression 7.1:1; elec engine mgmt; fuel economy (est) 21/25 as quoted from this address: http://www.cars101.com/oldsubaru.html#1988 That leads to another Q. Was there special requests for builds you could work through dealer upon ordering? I did find my odd sube there with 8.7:1, again I am hoping the site is correct. Link to comment Share on other sites More sharing options...
MilesFox Posted September 6, 2006 Share Posted September 6, 2006 this sounds like the spider intake mpfi. i have seen non turbo on an 87 but not a turbo version in person. late 87 models and ones listed as "88" i would presume i guess it was the 84 brat had an automatic tranny for only one year (4wd) Link to comment Share on other sites More sharing options...
bgd73 Posted September 6, 2006 Author Share Posted September 6, 2006 the info at cars101.com is wrong this address revealed normal numbers: http://subaru.sonik.us/techspecs.html it is safe to say all turbo ea82 oem are 7.7:1 (?) Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted September 7, 2006 Share Posted September 7, 2006 it says my 83 gl10 4wd didnt have power windows or anything else power. i have every thing power even the power mirrors even though i never seen anything to adjust the mirrors. Link to comment Share on other sites More sharing options...
mikeshoup Posted September 7, 2006 Share Posted September 7, 2006 Bear in mind, sites like cars101.com gather all the information from various sources, many of which are wrong. You can safely say, all EA82 Turbos are 7.7:1. My 86 FSM says so, my 88 non-XT FSM says so. The best source for specifications is your owner's manual, or an FSM. You'll be amazed at all the specifications listed in your friendly owner's manual. Link to comment Share on other sites More sharing options...
Joey Joe Posted September 7, 2006 Share Posted September 7, 2006 my 90 loyale turbo does 100 +, no problem, just the suspension doesnt like it. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 7, 2006 Share Posted September 7, 2006 it says my 83 gl10 4wd didnt have power windows or anything else power. i have every thing power even the power mirrors even though i never seen anything to adjust the mirrors. It used to be locted next to your stock radio, but when you cut the console for an aftermarket deck, there is no place for the switch. So most just eliminate it. GD Link to comment Share on other sites More sharing options...
Hondasucks Posted September 9, 2006 Share Posted September 9, 2006 When I did my 83, I cut the hole out at the bottom as you mentioned, and I just took the ash tray out and put the power mirror switch where the ash tray was (you have to sort of wedge it in there, but it fits) Link to comment Share on other sites More sharing options...
bgd73 Posted September 9, 2006 Author Share Posted September 9, 2006 Bear in mind, sites like cars101.com gather all the information from various sources, many of which are wrong. You can safely say, all EA82 Turbos are 7.7:1. My 86 FSM says so, my 88 non-XT FSM says so. The best source for specifications is your owner's manual, or an FSM. You'll be amazed at all the specifications listed in your friendly owner's manual. The closest I have to a fsm is from here in pdf, I was enthused enough to print it and laminate the pages.(60 bucks!) I also have a chiltons and haynes. I keep an eye out on ebay where I got my other book... but FSM sure seems a rare item. My 93 also has a rradio wiring not found in normal info. I luckily didn't want to use the oem shared ground. The FSM seems all the more in need after that find. Link to comment Share on other sites More sharing options...
