TurboTbird Posted September 9, 2006 Share Posted September 9, 2006 I'm planning on doing some tune-ups to my 95 legacy LS with 66k on the odometer. I changed to a K&N panel filter, I want to change the plugs and wires, and change the fluids. I want NGK plugs. is there a good part number or type for them? What about wires? I also use mobil 1 for oil, what should I use for the tranny, rear, etc.? Thanks for the help, I searched for some of this stuff already... Link to comment Share on other sites More sharing options...
porcupine73 Posted September 9, 2006 Share Posted September 9, 2006 Hi TurboTbird, plugs are probably BKR6E-11 or check out ngksparkplugs.com Wires you could go OE or aftermarket are available, depends on what price you want to pay and what you're looking for. If you like Mobil1 engine oil, you could try Mobil1 synthetic ATF, it worked well for me. Diff gear oils there's some threads that say not to use Mobil1 synthetic gear oil in Subaru diff's due to some potential incompatibility in the metals. amsoil makes a nice synthetic atf and gear oils too. Link to comment Share on other sites More sharing options...
nipper Posted September 9, 2006 Share Posted September 9, 2006 I'm planning on doing some tune-ups to my 95 legacy LS with 66k on the odometer. I changed to a K&N panel filter, I want to change the plugs and wires, and change the fluids. I want NGK plugs. is there a good part number or type for them? What about wires? I also use mobil 1 for oil, what should I use for the tranny, rear, etc.? Thanks for the help, I searched for some of this stuff already... plug wires should be OE. Fuel filter needs to be changed. You need to think about the timing belt, as the age is determined by 1000 miles a month, so even though your mileage is low. 80,000 miles is 80 months for example. PCV valve should be OE. New T stat (oe) and radiator cap. New coolant. OE airfilter or name brand is the best in all truthfullness. WHen in doubt about lubricant, use name brand for the diffs. nipper Link to comment Share on other sites More sharing options...
