Sonicfrog Posted September 10, 2006 Share Posted September 10, 2006 Did they use them on the GL 10's, or just the RX??? Link to comment Share on other sites More sharing options...
mikeshoup Posted September 10, 2006 Share Posted September 10, 2006 GL-10s had them as an option, and so did practically every subaru. You'll mostly find them on FT4WD Turbos though. Link to comment Share on other sites More sharing options...
Phizinza Posted September 10, 2006 Share Posted September 10, 2006 You really just have to look for the "LSD" writin on the case.. Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 30, 2006 Author Share Posted September 30, 2006 Is the front and the rear both LSD or just the front? Link to comment Share on other sites More sharing options...
Phizinza Posted September 30, 2006 Share Posted September 30, 2006 Rear only. Only subies that came out of the factory with front LSD's are STi's, and I am not sure if all of those had them even... Link to comment Share on other sites More sharing options...
edrach Posted September 30, 2006 Share Posted September 30, 2006 Stock LSD was 3.700 ratio; easy to convert to 3.900 for use on most of the EA81 and EA82 models. Link to comment Share on other sites More sharing options...
beataru Posted September 30, 2006 Share Posted September 30, 2006 The good thing is if you find one... it'll bolt right up....I love subarus Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 30, 2006 Share Posted September 30, 2006 beataru said: The good thing is if you find one... it'll bolt right up....I love subarus Whoa there tiger, make sure to get all the facts first. It will physically bolt into any EA subie, provided its 4wd, but it won't work on all of them, LSD's came in turbo cars,which were all 3.7 ratio, they won't work with non turbo cars, or cars with MT's unless the LSD is taken out of the 3.7 diff and put into a 3.9 diff, if you miss this rather important step you'll blow up your drivetrain. Link to comment Share on other sites More sharing options...
beataru Posted September 30, 2006 Share Posted September 30, 2006 NoahDL88 said: Whoa there tiger, make sure to get all the facts first. It will physically bolt into any EA subie, provided its 4wd, but it won't work on all of them, LSD's came in turbo cars,which were all 3.7 ratio, they won't work with non turbo cars, or cars with MT's unless the LSD is taken out of the 3.7 diff and put into a 3.9 diff, if you miss this rather important step you'll blow up your drivetrain. i am assuming people who will switch out there drivetrain knows there ratio beforehand...... Link to comment Share on other sites More sharing options...
RONAN Posted September 30, 2006 Share Posted September 30, 2006 NoahDL88 said: Whoa there tiger, make sure to get all the facts first. It will physically bolt into any EA subie, provided its 4wd, but it won't work on all of them, LSD's came in turbo cars,which were all 3.7 ratio, they won't work with non turbo cars, or cars with MT's unless the LSD is taken out of the 3.7 diff and put into a 3.9 diff, if you miss this rather important step you'll blow up your drivetrain. Just wanted to say that I bought a new 4wd GL wagon off the lot in 87 that had a 3:70LSD. It was NOT a turbo. From what I`ve gathered, I had an extreme rarity, but they ARE OUT THERE:headbang: Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 30, 2006 Share Posted September 30, 2006 beataru said: i am assuming people who will switch out there drivetrain knows there ratio beforehand...... It has been assumed before, with disasterous results, thats why I always remind people of the difference. Link to comment Share on other sites More sharing options...
