patcal Posted November 7, 2003 Share Posted November 7, 2003 Hi all, Can you replace the duty solenoid c without removing the tranny tail housing? I am getting a code 24 with is the solenoid. Tomorrow I am going to get under the car & check the solenoid. I would like to know so I can buy the gasket while at the dealer getting the solenoid. Thanks. Link to comment Share on other sites More sharing options...
Legacy777 Posted November 9, 2003 Share Posted November 9, 2003 nope, you have to remove the rear extension housing to get at the duty c solenoid. Make sure you test the wiring to the solenoid to make sure that's not the problem. What symptoms are you having, other then light being on & that code stored. Link to comment Share on other sites More sharing options...
patcal Posted November 9, 2003 Author Share Posted November 9, 2003 Josh, Bad torque bind. Installing the fuse helps a little but when I check the duty solenoid I get a open. From what I can find that will put the AWD into 50/50 regardless of the fuse. I have already checked tires & changed all the fluids. Anything I might have overlooked? Thanks. Link to comment Share on other sites More sharing options...
Legacy777 Posted November 9, 2003 Share Posted November 9, 2003 I guess check the wiring to the sensor, if all looks good, you could try testing the sensor......other then that.....not really sure....other then the sensor being bad. Link to comment Share on other sites More sharing options...
patcal Posted November 9, 2003 Author Share Posted November 9, 2003 I will check fro continuity from TCU harness to the soenoid if I can find the connector at the tranny. Also, is there anyway to know if the clutch packs are bad while I have the extension housing off? Link to comment Share on other sites More sharing options...
Legacy777 Posted November 9, 2003 Share Posted November 9, 2003 I'm sure there is a way to look at the clutch packs and tell. I'm not exactly sure what they should look like new/used, etc. Link to comment Share on other sites More sharing options...
