swilde20 Posted September 11, 2006 Share Posted September 11, 2006 95 legacy awd wagon could a person install the rear struts from the same car in the front? if so what changes if any would i have to make? thanks steve Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 11, 2006 Share Posted September 11, 2006 at a minumum you would have to change the caps, as they allow you to turn the wheels, which unless you only want to go in straight lines is rather helpfull. also the rear struts don't have the same setup for adjusting camber, so that would also have to be modified, so unless you go a wicked awesome idea up your sleeve, this is probably not the greatest use of rear struts. Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted September 16, 2006 Share Posted September 16, 2006 actually. you cant use the rears in the front..... i already tried this once while i was in the process of swaping my struts.... the hole for the strut to go through in the strut top isnt big enough for the strut shaft. so it wouldnt go on correctly. if you did put it on, you wouldnt have enough threads to put the nut on and really get it tight like your supposed to....... Link to comment Share on other sites More sharing options...
