dbarber Posted September 11, 2006 Share Posted September 11, 2006 Hi all, The rear cat on my 95 Legacy wagon cracked. I took it to my regular mechanic, who is still learning his way around Subarus. He told me that my car is built to California emissions standards, even though it was bought new in Delaware. He said the ONLY place to get a cat is from the dealer, for $420, with a total estimate of $580 if the oxygen sensor comes out without breaking. $720 if he has to replace the oxygen sensor. This sounds outrageously high to me. He says that you can't use the non-California cat, as the sizes are not the same. Is he talking PURE bull? The numbers just sound outrageous to me. Is it true that a generic cat will not fit or work? Is there something that I can do that is MUCH less expensive? PLEASE help! Link to comment Share on other sites More sharing options...
porcupine73 Posted September 11, 2006 Share Posted September 11, 2006 Some number of states now require 'California emissions' so that is probably true. I don't know if the cats for federal and CA emissions are different. Generic cats aren't always the best even if you can find one; cats are expensive because they have platinum or palladium or something in there as the catalyst which is 'spensive. Another option could be a salvage yard. Sometimes emissions components are required to be warranted for 100k miles or something, but I don't know if that would cover the crack. Link to comment Share on other sites More sharing options...
Manarius Posted September 11, 2006 Share Posted September 11, 2006 I call BS on that. You're in West Chester, PA. Outside of the Philadelphia zone of emissions testing. You could probably get away without that second cat and still pass emissions just fine. Link to comment Share on other sites More sharing options...
nipper Posted September 11, 2006 Share Posted September 11, 2006 there are ton of places to get catalytic converters. You REALLY need a new mechanic. DO a search on google, also i buy my cats when i need them from JC Whitney. nipper Link to comment Share on other sites More sharing options...
dbarber Posted September 11, 2006 Author Share Posted September 11, 2006 Can someone recommend a good independent Subaru mechanic in my area (19380)? This guy is apparently just going by what the book says are the part numbers. Also, can the shell of the cat be repaired? Would a "generic" cat have a boss for the oxygen sensor? Link to comment Share on other sites More sharing options...
Suzam Posted September 12, 2006 Share Posted September 12, 2006 This place: http://www.convertergeek.com/content.wws?fname=california.html&cookieID=1W8180KIR1W8182IGI&clientid=convertergeek claims to sell certified cats for CA. I'd call Concordville, Rafferty or Matt Slap Subaru and talk to someone in the parts department about the differences in the rear cat. Tell them what you know and that you're thinking of doing it yourself and ask what, if any difference there would be between the 2 cats. You might find that you can use the 49 state converter or ta least you'll get better facts. Link to comment Share on other sites More sharing options...
Manarius Posted September 12, 2006 Share Posted September 12, 2006 You don't need CA level cats in this state. Sorry, but I live here. I know these things. Link to comment Share on other sites More sharing options...
cookie Posted September 12, 2006 Share Posted September 12, 2006 I'm not sure if they are still available but there used to be a place in Hayward CA that sold rebuilt cats. I put one on my old Mercedes and it was still going a few years later when I sold it. Link to comment Share on other sites More sharing options...
Mikevan10 Posted September 12, 2006 Share Posted September 12, 2006 I don't know about West Chester, but in my neck of the PA woods (that's redundant isn't it), it's all about OBDII. You could be belching anything out of your exhaust pipe but as long as OBDII (Big Brother) doesn't know it you are golden as far as an "emmissions" sticker goes. Great system, aint it? Link to comment Share on other sites More sharing options...
johnceggleston Posted September 12, 2006 Share Posted September 12, 2006 that's what i thought. so as far as inspection goes, as long as the computer is happy, it doesn't matter what cat you have. go to the salvage yard. I don't know about West Chester, but in my neck of the PA woods (that's redundant isn't it), it's all about OBDII. You could be belching anything out of your exhaust pipe but as long as OBDII (Big Brother) doesn't know it you are golden as far as an "emmissions" sticker goes. Great system, aint it? Link to comment Share on other sites More sharing options...
lmdew Posted September 12, 2006 Share Posted September 12, 2006 Most places can not resell CATs, but ask the yards in your area. The length of the pipes are all the same. They may look a little different, but I've bolted up many different years and models. Good Luck finding a good one. Link to comment Share on other sites More sharing options...
dbarber Posted September 13, 2006 Author Share Posted September 13, 2006 Well, I finally got to actually see the damage. The pipe leading out of the rear cat is broken right where it leaves the cat. There is some spring loaded connection right after the break. A local muffler shop had a generic cat that they could weld a bung in for the oxygen sensor. They would then have welded in a peice of "flex pipe" to replace the spring loaded connection, which is rusted. They want $450 to do this, which is better than the $600 estimate from local mechanic. Any thoughts? Link to comment Share on other sites More sharing options...
nipper Posted September 13, 2006 Share Posted September 13, 2006 Well, I finally got to actually see the damage. The pipe leading out of the rear cat is broken right where it leaves the cat. There is some spring loaded connection right after the break.A local muffler shop had a generic cat that they could weld a bung in for the oxygen sensor. They would then have welded in a peice of "flex pipe" to replace the spring loaded connection, which is rusted. They want $450 to do this, which is better than the $600 estimate from local mechanic. Any thoughts? i dont like it. The factory set up lasts for alomost the life of the car. depending upon how long you want this car to last is up to you. That spring loaded thing is the flex joint for the exhaust system. http://www.ecatalyticconverter.com/ nipper Link to comment Share on other sites More sharing options...
jjou812 Posted September 14, 2006 Share Posted September 14, 2006 do a search. i remember reading on this site a few months ago several people complaining about "Eastern" brand converters, instead recommending "Walker" brand. Link to comment Share on other sites More sharing options...
nipper Posted September 14, 2006 Share Posted September 14, 2006 do a search. i remember reading on this site a few months ago several people complaining about "Eastern" brand converters, instead recommending "Walker" brand. i always use walker pipes if im doing it myself. The cats i got from JC WHitney were walker. nipper Link to comment Share on other sites More sharing options...
WINKK Posted September 15, 2006 Share Posted September 15, 2006 I recently had my exhaust break in the same place. Got all kinds of outrageous quotes from dealer and aftermarket ($400-650). I had about given up when I remembered that I hadn't checked with the local NAPA store. They had it in stock and it was only 200 bucks. My subie is a 91 wagon and does not have the rear o2 sensor like yours, but its worth a check to see if they have it for that cheap. Link to comment Share on other sites More sharing options...
