my puggys
HATCHY
chef_tim found the longer studs IIRC.
you don't need new studs, however. you just need the pug lug nuts. as they have large centering washers on them, or get the ball seats. find the post stickied in the wanted section, McBrat posted a link to the ball seats that allow you to use the subaru nuts with pug alloy wheels
  SOOBOUTLAW said:
I tried to put Pug nuts on Soob lugs, but it wouldn't thread. I tried several different nuts on several different lugs, no dice. Stock nuts (Soob) work just fine with the lugs (and 14" steelies I'm rollin now). Dunno why, haven't checked thread pitch of either yet.
then you must have had the wrong nuts or something....
either way, you only need the pug nuts if you're using alloy wheels. as they need the big centering washer. not necessary for the steelies.
