mykingcrab Posted September 15, 2006 Share Posted September 15, 2006 The 85 rx (87 motor/)runs strong,and 1500k miles now (since I bought it from nug) I have had no probs.and 4xs killer p/t d/r(l.s.d.)sedan. Problem is: When I slowly raise the rpms,it has a consistant slight flutters. till about 3000+ and then it goes away.When im driving at or in normal conditions you can always feel it pulse constantly .even when you floor it. I ran Lucas injector cleaner thru, I changed the plugs(old ones had alot of use,but had evedinces of proper burning) no leaks (in dark) on the plug wires, O'reillys gave me a carby cap/rotor so i couldnt change that, but cleaned up the old ones and they looked good.(can still have hidden probs).Some days it still fludders but seems to haul ss alot quicker. my thoughts were (since ive seen the tack jump a few times),that the distributer bushings are wore?,Or possably the injectors/fuel system might need some attention? Im sure alot of you guys will help me figure it out since youve probably been there done that. thanks.mkc My friend hates accell coils and it has one.(is it the coil)? P.s. Its been 6 weeks (busy)I want to thank Nug and Meekymoose for all there help in making my 2400 mile r/trip alot easier to get the RX and the wheels home to the ozarks. and tony,those German subaru factory 14s look killer,I have had people ask were can they get a set:slobber: you were right,I (may) never see another set in the U.S. Quote Link to comment Share on other sites More sharing options...
mykingcrab Posted September 15, 2006 Author Share Posted September 15, 2006 I reworded my thread because,like a normal person that is not computer/internet experienced,I made a bad choice of words in the discription of my cars most recent need for repair. If any one was rubbed wrong,or hurt by this I offer my apologies.10 people read it before I changed it. good lesson. life has given us all differnt challenges and struggles. Anyway, whats the answer do you know GD in portland? Quote Link to comment Share on other sites More sharing options...
calebz Posted September 16, 2006 Share Posted September 16, 2006 I read it before it was changed.. My butt doesn't hurt. Did I miss something? Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted September 16, 2006 Share Posted September 16, 2006 Does it have a boost/vacuum gauge, and have you checked for play in the turbo shaft? Quote Link to comment Share on other sites More sharing options...
mykingcrab Posted September 16, 2006 Author Share Posted September 16, 2006 spools and boost 7 lbs every time.Not sure if its a fuel or spark ,or distrib. prob,turbo is fine. its more annoying than anything.it pulses and is especialy noticable in normal conditions like driving at 45 mph under no load,foot barly on the gas 0 vac/0 boost. it has a slight studder.and if i floor it it scrams,but same pulsing.if im under the hood,and use the cable by hand,and slightly raise the rpms slowly it has a slight hesetation till about 3k then smooths out everytime. Quote Link to comment Share on other sites More sharing options...
wes200x Posted May 31, 2007 Share Posted May 31, 2007 I don't know if this helps but my rx was having a similar problem. just before it went on to boost it had a surge shutter then cleared up. It almost felt like the clutch slipped then grabbed again. My car also had a crappy idle. It idled really low or at about 1100. Well it turned out to be a leaking injector. Yesterday I replaced all 4 and now it is perfect. Idles is smooth as silk and no more shutter before boost. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted May 31, 2007 Share Posted May 31, 2007 I have a similar problem on my wagon, but I know there is a worn injector or two. I guess this means I'll be taking my spare set to the Witchhunter!!! http://www.witchhunter.com Quote Link to comment Share on other sites More sharing options...
mykingcrab Posted June 1, 2007 Author Share Posted June 1, 2007 Cool. if my check list doesnt fix it this will be next. Does any one have a source? or a price? THNX everyone Quote Link to comment Share on other sites More sharing options...
beataru Posted June 2, 2007 Share Posted June 2, 2007 well.. dont think this will help but you can use the Nissan Zeeeees lineup of fuel squirters but thats really only if you wana go more boost, and in that case you better get a SFAC to controll it.... Anyways about the problem, I think that it could be a fuel problem or ignition problem.... The symptoms work perfectly in both conditions... this probably wont help either but, if you have a friend with an oscillo scope (hard word to spell) than that would easily and quickly rule out the ignition... but then again so would replacing the injectors.... hope it helps, even a little! Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted June 2, 2007 Share Posted June 2, 2007 Ive heard that late model evo injectors will fit. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted June 2, 2007 Share Posted June 2, 2007 Thats an evo injector. One could probably make it work. Quote Link to comment Share on other sites More sharing options...
Subi81 Posted June 3, 2007 Share Posted June 3, 2007 My 86 t wagon does the same thing. Kinda feels like the clutch grabs then lets go then grabs then lets go etc. all the way up to 3400 rpm. I have an Air/fuel ratio gauge on my car and the surges are timed exactly to the air/fuel ratio. Lean = not so much power, rich=power. After watching this for 3 years this is what I think is going on: Anything below 3400 rpm the ecu will try to achieve a stoiciometric mixture thus the fuel ratio bounces back and forth between rich/lean giving the power/no power situation. After 3400 rpm the system goes into a power mode and just throws a bunch of fuel at the engine, thus smooth power. I have just learned to live with it. A new O2 sensor will respond to a change in the fuel ratio faster and will lessen the surges but not completly eliminate them. Good luck Quote Link to comment Share on other sites More sharing options...
joostvdw Posted June 3, 2007 Share Posted June 3, 2007 My 86 t wagon does the same thing. Kinda feels like the clutch grabs then lets go then grabs then lets go etc. all the way up to 3400 rpm. I have an Air/fuel ratio gauge on my car and the surges are timed exactly to the air/fuel ratio. Lean = not so much power, rich=power. After watching this for 3 years this is what I think is going on: Anything below 3400 rpm the ecu will try to achieve a stoiciometric mixture thus the fuel ratio bounces back and forth between rich/lean giving the power/no power situation. After 3400 rpm the system goes into a power mode and just throws a bunch of fuel at the engine, thus smooth power. I have just learned to live with it. A new O2 sensor will respond to a change in the fuel ratio faster and will lessen the surges but not completly eliminate them. Good luck I have the same "flutter" of what you might call it, but I have no O2 sensor so I guess that is not the real reason why it behaves like this (I have a non-smog controlled EDM version, no cats, no O2, etc.) Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted June 3, 2007 Share Posted June 3, 2007 I have the same "flutter" of what you might call it, but I have no O2 sensor so I guess that is not the real reason why it behaves like this (I have a non-smog controlled EDM version, no cats, no O2, etc.) Bastard.... Quote Link to comment Share on other sites More sharing options...
Nug Posted June 4, 2007 Share Posted June 4, 2007 I have no idea if this has anything to do with it, but it was my understanding that the turbo was the original one with the car, and it's the base engine that was replaced. So the turbo has a quarter million on it. Although it sounds like others are working on a solution, so that's good. Quote Link to comment Share on other sites More sharing options...
