powderhound Posted September 16, 2006 Share Posted September 16, 2006 I have the first symptoms of torque bind after long runs on the highway. What I am wondering is if the VC from a 92 legacy will work in my 98. Also how difficult is it to remove/install? Link to comment Share on other sites More sharing options...
porcupine73 Posted September 16, 2006 Share Posted September 16, 2006 If you're in the first stages, have you tried changing the ATF with a good product (i.e. not coastal) or maybe even synthetic? It could just be some gunk starting to build up. Link to comment Share on other sites More sharing options...
nipper Posted September 16, 2006 Share Posted September 16, 2006 First question is is it it an auto or manual. Second do all the tires match. i dont know if a gen1 wil accept a gen2 nipper Link to comment Share on other sites More sharing options...
powderhound Posted September 17, 2006 Author Share Posted September 17, 2006 I thought that was obvious since only manuals have a viscous coupling. Link to comment Share on other sites More sharing options...
nipper Posted September 17, 2006 Share Posted September 17, 2006 powderhound said: I thought that was obvious since only manuals have a viscous coupling. A lesson on this board i learned, never assume anything. More then once people with auutomatics have thought they have had VC and center diffs, and visa versa. nipper Link to comment Share on other sites More sharing options...
BigMattyD Posted September 17, 2006 Share Posted September 17, 2006 nipper said: A lesson on this board i learned, never assume anything. More then once people with auutomatics have thought they have had VC and center diffs, and visa versa. nipper For example, the second post advises you to change your ATF... Link to comment Share on other sites More sharing options...
nipper Posted September 17, 2006 Share Posted September 17, 2006 BigMattyD said: For example, the second post advises you to change your ATF... yup just like that. nipper Link to comment Share on other sites More sharing options...
porcupine73 Posted September 19, 2006 Share Posted September 19, 2006 Yah I wish I knew what the author of the second post was thinking. I think it just goes to show what can result from making assumptions and not knowing what you're talking about. Link to comment Share on other sites More sharing options...
