Soobie experts please share known issues swapping 2.5's for 2.2's;
If you know what threads to search please share that as well, my car is a 97 Outback Legacy 2.5 with AT/ 4WD.
As always, thanks in advance for all of your technical help and inspiring motivation.
Happy Motoring!
Happy Motoring!
There really aren't any. Be sure you get the correct four exhaust port 2.2 motor with EGR, complete with intake manifold and all that jazz. You have to reconfigure a few hoses to prevent a CEL from coming on due to the lack of an underhood charcoal canister in the 2.5 cars. On some vehicles, you have to mix and match brackets for the A/C compressor. The power steering hoses don't line up with the support brackets (I just blew this off & let them float free...they don't really seem to need all that much extra bracing.) Make sure you don't clobber the torque converter when reinstalling the engine. (Mine is a stick, so I can't help with A/T advice beyond that.) Good luck!
Nathan
Going to make this simple for you as I have done the 2.5 to 2.2 on a Legacy Outback. I used a 97 2.2.
From the donor car (450 dollars tops)
1) Engine / use the exhaust manifold from the 2.2 donor
2) AC Compressor you must keep and hoses from your 2.5 mount onto the 2.2
3) Metal Power steering lines from the 2.5 move them over
4) The fly-wheel from the 2.5 will have to be moved over to the 2.2.
From Subaru
1) All new exhaust gaskets (10 dollars)
2) new o-rings for the AC hoses you disconnect
3) new o-rings for the power steering lines you disconnect
From Walmart
1) 2 cans of 12 oz refrigerant and a refill hose (30 bucks)
While you are at it replace this on the 2.2 donor (100 bucks) an easy to do with the engine out.
1) Harmonic balancer (50 ebay)
2) AC and Alternator belts (20 pepboys)
3) Rear cam seal (5 dollars)
4) Oil Separator Plate (sure to be leaking, original is plastic) (15 dollars)
5) Rear main seal. (20 dollars)
6) Spark Plugs (10 dollars)
7) PCV Valve ( 8 dollars)
8) Valve cover gaskets (2 of these) and grommets for the bolts (30 dollars)
9) Reseal the oil-pan and replace both gaskets that are internal. (RTV temp sealer 4 bucks, gaskets are 10 bucks)
